7/15 Blend Date Folks
Apugh67
Anthony
Circleville, OH
2008 F350, 2017 Lincoln MKZ, 2018 Escape
J
British Columbia
2017 F350 Supercrew LB
That's just the last 8 of your VIN, since we're not built in sequence of VIN, don't think it really means much sadly.
True, VIN is not an indication of build sequence, however that is the highest VIN number I've seen and mine is several thousand lower, so I'll continue to hold out hope for a blend date.
ApexNCBronco
The Chad
Apex NC
Yukon
Found this on another thread! Going to buy it and toast on when I take delivery!
Ford Bronco 7/15 Blend Date Folks BF41E02D-5455-4BF5-9A8D-9C99AC499702
LetRBuck
Aurora, CO
C7 Corvette, Toyota Highlander
Check out the 7/14 thread. Sounds like rotation 5000-5500 will be tomorrow so running behind the blend date.
5280Bronco
Denver
I thought that was today, and tomorrow was going to be 5501-6000. Oh well, ours will be built Monday or Tuesday.
ApexNCBronco
The Chad
Apex NC
Yukon
Sure it’s been asked but average time after build for delivery? Hoping to get mine before week at NC beaches where I can take it out on the sand dunes!!
LetRBuck
Aurora, CO
I looked again. You’re right, maybe 5000-5500 today and 5501-6000 tomorrow. Still behind a bit but also mentioned that maybe they are closer to the blend date timing and just not updating in the system. Either way getting really close!
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
I
Mind giving instructions on how we get the “sync “ app? Not seen that before? Does it give more info than the tracker?
Its in your Ford account.
Add your bronco VIN and you can check if the Sync is updated. If it shows a date, you’re likely built.
R11
Rob
Sparta, Tennessee
www.basequatch.com
Bronco Base Sasquatch 2.7
I guess I can go start a 7/16 blend date thread, as I have not seen one, but from going through these posts, I take it generally they are about a partial day behind right now? Are they working a Saturday shift this week? Seems like my basequatch build puts me on the front end of the work day after 7/16 if that's about right.
Ford Bronco 7/15 Blend Date Folks Screen Shot 2021-07-15 at 9.51.08 PM
DudeBronco
Nashville
2021 Bronco Badlands, 2015 GMC Sierra
I'm right behind ya...
Ford Bronco 7/15 Blend Date Folks 1626400479459
g8rb8t
Brad
Marietta, GA
74 Bronco
7/15 Blend
Ford Bronco 7/15 Blend Date Folks Screenshot_20210715-221153_Offic
