bcb1
Brad
Martinsburg, West Virginia
2017 BMW X5
I really like them. I'm just not sure that I like them $600 worth 😁 .
Was the install bolt on/clip on only? Or did you need to use double sided tape on the install? I might go for these, if they are reasonably easy on/easy off, so I could go back to the OEM flares if I ever wanted to.
Amcole1984
Amcole1984
Amber
2021 2 door Bronco Big Bend
They definitely aren't easy on/off. They are installed with a combo of bolts/clip using factory mounting holes and 3m tape.
BigHoof
PA
Ram 2500
joell king
Canada
bronco 6g
Looks amazing ! good job
Yeti-X
Todd
Eau Claire WI
2022 Bronco Badlands 4dr
BustinPeppers
Lucas
Charlotte TN
'22 AudiS7-'12 Denali-'23 Bronco (Ford is Hiding)
Nice look, good job
Amcole1984
Amcole1984
Amber
They look awesome do they add any additional tire coverage
No. They are actually a lot closer to the body than the stock flares.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Cut out the rounded part and 👌
I can't wait to see this done, that weird arch is the big thing holding me back. There's no going back afterwards though.
  • Like
Reactions: 0ne
AustyPosty
Austin
2 Door 2017 Jeep Wrangler
The square look almost makes it seem like you also added a small lift. Not bad at all!
I've been shocked at how tiny a Jeep looks next to a Bronco.
One was built for tight trails. The other was built for wide open desert
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
@Bestop_Team - Cut the roundness out of these and I think you'll sell a whole bunch more. Nevermind I'm an idiot...
Other than that, these look good!
BigHoof
PA
Ram 2500
Don't think that is possible. The metal fender is still back there.
604Bronco
British Columbia
www.bronco6g.com
Ah, my bad - I thought that was part of the fender design but I understand now. Damn it!
Someone give @Tricky Dick a saw...
