- AA
- Nov 16, 2022
- 52
- 811
- 3,159
- California
- !!!FOR SALE!!! 2022 Bronco® The Sasquatch™ 2-door
- Outer Banks
I've wanted to install a lamp in the glove box of my Bronco since the day I drove it off a dealer's lot. I don't know why such a simple convenience is not part of the Lux package.
I started to browse the web looking for a lamp that would perfectly fit in the area surrounding the glove box, wouldn't require too much trimming, and something that would look as if Ford hadn't cheap out and had installed it at the factory.
Unfortunately, I couldn't find any glove box light made for Ford, Lincoln, or Mecury models that would work for the Bronco. In my case, the perfect solution came from Hyundai. If any Blue Oval purists are reading this thread, I beg your pardon.
I looked for a lamp that had an external swich because it would be easier to find a good spot for two smaller parts that for a larger all-in-one unit. The Hyundai lamp I used is often sold as a kit: a lamp, switch, and wire harness. Here are the numbers of all these parts: 92620-33000, 93510-21000, 91180-2D900. The kit cost me $19+tax.
The lamp fits perfectly in the upper lip of the housing that surrounds the glove box.
The best spot for the switch is right next to the left latch hole. I cut out the rectangular holes using a small hand drill and Tamiya hand saw.
Before cutting this holes in the Bronco, I test fitted the lamp and switch in a piece of plastic of the same thickness to make sure they wouldn't wiggle or fall out. After I was happy with the size of the cut outs, I used this plastic piece as a stencil and marked the cut line with a white thin tip marker.
I had to squeeze myself in between the passenger seat and the dashboard to be able to cut the hole for the lamp. I'm glad the plastic is pretty soft, so it didn't take me much time to complete this task. If I were a bigger guy, I would have needed to unbolt the passenger seat.
OCD didn't allow me to cut the brand new Hyundai wire harness, so I also purchased a used female electrical connector of the same Korean brand. There aren't any junk yards around the area I live in, so eBay helped me out once again. I don't know the part number, but I'm sure it was used by Hyundai and Kia over many years for iterior lighting.
I soldered 20 AWG wires to this connector and routed them to the Ford connector hiding behind the passenger's A-pillar plastic trim. The two wires I spliced feed power to the lamps in the sun visors.
I installed the lamp in the glove box while retroffiting the upfitter switches and adding a roof light bar. This video provides excellent instructions on how to disassamble the interior and get to the electrical connector on the A-pillar.
I'm super happy with the result. Now I can see the stuff lying in the glove box any time of the day. I hope this write up helps you bring more light into your Bronco.
