Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Jeep LJ, Ford Ranger, Ford Bronco
Ford Bronco ARB Intensity IQ – The Next Step in Driving Light Innovation: Smart lights that do it all ARB-IQ-Intensity-Lights-Bronco-FB-Cover-1702-x-630
The most advanced driving lights we have ever created are here. Introducing ARB Intensity IQ – the smart driving light that does it all.
Times have changed and access to new technology is ever-increasing. The ARB Intensity IQ was developed from the ground up, with performance front of mind, while delivering a design that complements modern vehicle styling and front bumper design. Packed with unique-smart features, the Intensity IQ sets a new level of driving light design and usability.
Ford Bronco ARB Intensity IQ – The Next Step in Driving Light Innovation: Smart lights that do it all IQ Breakdown
THE FOUR-OPTIC DESIGN
A unique four-optic design (Super Spot, Spot, Flood, and Midrange) is employed to provide virtually an unlimited choice of light beams to suit any road condition.
  • The Super Spot and Spot optics, based on free-form reflector technology, produce an even spot beam for extended distance illumination.
  • The Flood optic has a specially designed lens to maximize the light spread for excellent foreground visibility.
  • The Midrange optic employs a conventional parabolic reflector to illuminate the midrange area.
  • The beam pattern of each of the two lights can be independently adjusted so you could run, for example, one focused on spot and one focused on flood.
Ford Bronco ARB Intensity IQ – The Next Step in Driving Light Innovation: Smart lights that do it all Screenshot at Dec 23 12-33-33
Ford Bronco ARB Intensity IQ – The Next Step in Driving Light Innovation: Smart lights that do it all Switch 2
CUSTOMIZABLE ONBOARD SWITCH
A physical switch controller that is equally as intuitive accompanies the revolutionary Intensity IQ lights. Access up to eight different preset configurations at the click of a button, instantly changing the Intensity IQ lights to suit your needs. The Intensity IQ controller sports a design that is both ergonomic and practical, with users being able to feel and adjust rather than relying on seeing the device itself.
ARB INTENSITY IQ APP
Whether you plan to utilize the lights on-road or off-road, finding the right balance of lighting when can be challenging. ARB has taken this into account when designing the ARB Intensity IQ app. The user-friendly application allows users to control and set thousands of different light combinations from their mobile device. The on-board switch is also fully customizable via the ARB Intensity IQ app.
Ford Bronco ARB Intensity IQ – The Next Step in Driving Light Innovation: Smart lights that do it all Mounting bracket 2
INNOVATIVE MOUNTING BRACKET
Intelligent thermal management maximizes light output in all driving conditions and provides outstanding LED life expectancy. Cooling is maximized via the die-cast aluminum body which acts as a massive heat sink. An innovative, sleek new mounting bracket design not only allows adjustment of light beam angle, but also provides additional mass and surface for cooling.
OTHER KEY DETAILS
  • Light fade in/out preventing flash blindness
  • Adjustable light intensity and light beams
  • Courtesy light function
  • Work light function
  • Emergency light function
  • Sold as a complete kit (2X IQ lights, wiring harness, switch, and control module
Ford Bronco ARB Intensity IQ – The Next Step in Driving Light Innovation: Smart lights that do it all IQ Specs
SPECIFICATIONS & TECHNICAL DATA
  • LED Configuration
    • Super Spot: 4 x Cree XP-P LEDs
    • Spot: 2 x Cree XM-L3 & 3 x XP-p LEDs
    • Flood: 18 x Cree XT-E LEDs
    • Midrange: 4 x Cree XM-L3 LEDs
  • Raw Lumens
    • Max Spot 7,070 Lumens
    • Max Flood 14,060 Lumens
  • Effective Lumens
    • Max Spot 6,613 Lumens
    • Max Flood 6,666 Lumens
    • Max Combo 6,265 Lumens
  • Color Temperature
    • 5700-6200K
  • Operating Temperature
    • -40°F to +176°F
ARB Intensity IQ: Kit Part #ARBVX17 | MSRP $1850
Ford Bronco ARB Intensity IQ – The Next Step in Driving Light Innovation: Smart lights that do it all Spot Flood
Ford Bronco ARB Intensity IQ – The Next Step in Driving Light Innovation: Smart lights that do it all Spot v Flood (Drone)
Ford Bronco ARB Intensity IQ – The Next Step in Driving Light Innovation: Smart lights that do it all vehicleshot2
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Whoa, this is pretty unique! Excited to see how this ends up working
FleshTuxedo
A
PA
'22 OBX 2dr.
TAKE MY MONEY
HOSSMAN
HOSS
Boerne "Burn-E", TX.
'23 Badlands '24 IS 350 F-Sport '26 150 Tremor
Put 5 or 6 of those bad boys on the top windshield mount and wait for someone to flash you thinking your high beams are on and blast'm! Daddy like...oh daddy like a-lot!
Ground_zero298
Scs michigan
Those are pretty sweet. Can move from high speed to cruise to normal night driving on the fly.
On the lumens is that per light or the set? I’m assuming per light?
And amp draw?
Jr87mustang
Josh
Northern Cali
Zoinks. Almost $2k for a pair
Lol, I was going to jokingly say they are probably $900 apiece..... but I wasn't far off. I am sure someone will buy 5.
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
They've got the rep, so they charge accordingly. I passed on their compressor setup. Sure, this is an expensive hobby, but....whew!
Ocnorb
Western NY
2023 Ford Bronco Black Diamond 2-door Sasquatch
All these fancy high dollar lights out there...and yet they all still use garbage Cree emitters. If I can't swap dedomed Nichia 519a 4500k emitters into any aftermarket lights, I don't want em. They are the best LED emitters available right now, and only flashlight nerds like me know about them. I hope one day to have a Bronco headlight assembly to tear down and see if I can swap the emitters to something warmer like the 519a emitters. /end nerd rant.
OCNORB1974
Dale
Missouri
2022 Maverick
KT_bronco
Jon
So-CAL
Transit Connect Cargo
Learn something new everyday! Any pod light or bar you can recommend ? Or do you just look for ones that can be modded for max performance?
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
Look too spacey (not a proper word), and might look better on a Olds Tornado, as they would match the angles on that car..... :eek:
FLSTFI Dave
East TN
2018 Grand Sport, Carbon 65, 2017 F-150
Very interesting and expensive.
hozer
Calgary
Suburban
Looks rad, but you're playing yourself spending $2k on a pair of lights.
