Metalcloak
Metalcloak
Rancho Cordova, CA
2021 Badlands Sasquatch
kodiakisland
Arkansas
It’s hard to tell from the pictures, but how far below the frame does this sit? It’s looks like it will lose an inch or more of clearance under the transmission.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
based on the 4 door version that I currently have installed you will lose an inch or 2 of clearance, and will scrape the skids more than others. But it's full under body protection that I'm okay with hearing scrape. I think @Snacktime actually measured a before/after with his 4 door?
Bigguyry2000
Ryan
Southern California
2021 Black Diamond
Finally! I've been pestering your poor email for months haha.
My only question, why is everyone omitting protection on the exhaust side? Is there going to be a possible option for that in the future?
Lèòn
Jersey
Im interested, just when it comes to oil changes, do you have to remove everything or just one part?
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
You loose the 1" for most of the belly area. And around 2-3" in a few spots. I like that I don't rub my frame, you can take the skids off and there is zero damage.
This design is great for sliding, not avoiding rocks.
My issue is they needed to do more testing, I have wear in making undercloak skids hard to pull and reinstall.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Huge mess with my 2.3, oil goes into the transmission skid area. Going to pack rags everywhere next time.
Bigguyry2000
Ryan
Southern California
2021 Black Diamond
You need on of those Ronin drain plugs that you can attach a little hose to and clean drain everything.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
It's the oil filter, drain plug is free and clear in 30 seconds with an impact.
BeachTiger
Joe
South Carolina
2019 Ford F150, 2022 Bronco Badlands
Ford Bronco Bronco 6G Undercloak Skid Plates, 2-Door by Metalcloak pads
I've used these types of absorbent pads (like you train puppies with or for the incontinent) under oil filters and they work like a charm.
tyrobronco
CC
Central Florida
2021 Bronco,2017 Ford Fusion Energi
The 2-Door Undercloaks are here!
Features Include:
  • Strong 3/16 Formed & Welded Steel
  • Axle Skid Protection
  • Differential Skid Protection
  • Transmission Skid Protection
  • Transfer Case Skid Protection
  • Gas Tank Skid Protection
  • Flush Mount Hardware
  • Boat Sided Protection
  • Gold Zinc Chromate Coating
  • Made in the USA
Learn more and get yours at https://metalcloak.com/ford-bronco-two-door-undercloak-integrated-skid-plate-system.html
Neat. How is the Rocklander-style Bronco 2-door roof rack going?
Tcarp1
Travis
Newcastle, CA
2021 2 Door Badlands
Thats a good question! My bronco was the test mule for this system and the first with the setup. I actually just got my oil changed this last weekend and the shop didn't say anything about it so it must have been not a huge deal. Mine is a 2.7 though.
