Quake LED
Mr Bojangles
Denver
quakeled.com
HIGH DEMAND PRODUCT. FIRST COME, FIRST SERVED. PLEASE EXPECT POSSIBLE 2 WEEK DELAY.
ATTENTION BRONCO OWNERS!!!
Don’t use your Trail Sight or always thought it would look better deleted and be way safer with DRL and Sequential Turn Signals? Quake LED is proud to introduce our “First to Market” flush-mounted Tempest Series - Ford Bronco Trail Sight Delete Kit with DRL, Switch-back Sequential Turns and RGB Accenting!
These premium UV resistant Smoked Black lens DRLs feature a crisp white DRL that give a very sleek look, while our signature Tri-Phase Sequential Turn Signals inform on-coming vehicles that you are turning.
Check them out in action here:
With a complete DOT/SAE/ECE compliant, plug and play installation with built in anti-flicker resistors and easy to follow instructions, LED offers a construction and quality that is built to last. Go ahead and replace your stock 2021+ Ford Bronco Trail Sight!
Order model# QTE1192 today!
• COMPATIBLE with full sized Ford Broncos!
• PLUG and PLAY no splicing or wiring required!
• ALL Components included!
Trail Sight Delete Features:
• Function – DRL, Sequential Turn Signals & RGB Accenting
• Perfectly follows body for that flawless look
• No dash errors or hyper-flashing
• Watts – 3W DRL, 1.5W Turns & 3W RGB per side
• Current: DRL – 0.2A @12VDC per side
• Current: Turns – 0.1A @12VDC per side
• Current: RGB – 0.2A @12VDC per side
• Diodes – SMD 3528pcs LED
• Color Temp – 6,000K (DRL)
• Lens Material – Thick Polycarbonate
• Lens Color – Smoked Black
• IP66 Waterproof Rating
• Operating Voltage - 12V DC
• Operating Temp -40 to 140 degrees F
• Life Span Expectancy - 50,000 Hours
• Compliant: DOT/SAE/ECE
• Weight: 3.5lbs/set
• Size: 14 x 0.75 Inch
Fitment:
• 2021+ Ford Bronco with Factory Halogen Headlights (Base Tier)
• 2021+ Ford Bronco with Factory LED Headlights (High Tier)
Will not fit Bronco Sport
Included In the Box:
• Fully Assembled Driver and Passenger Trail Delete DRLs
• RGB Wires, Y Splitter and Controller
• Instructions
Buy here: https://quakeled.com/ford-bronco-trail-sight-delete-kit.html
Ford Bronco Quake LED Releases Ford Bronco Trail Sight Delete DRL Kit w/ Sequential Turn Signal and RGB Accenting QTE1199! 1199_Trail_Delete-01-6G
Ford Bronco Quake LED Releases Ford Bronco Trail Sight Delete DRL Kit w/ Sequential Turn Signal and RGB Accenting QTE1199! 1199_Trail_Delete-02-6G
Ford Bronco Quake LED Releases Ford Bronco Trail Sight Delete DRL Kit w/ Sequential Turn Signal and RGB Accenting QTE1199! 1199_Trail_Delete-04-6G
Ford Bronco Quake LED Releases Ford Bronco Trail Sight Delete DRL Kit w/ Sequential Turn Signal and RGB Accenting QTE1199! 1199_Trail_Delete-06-6G
Ford Bronco Quake LED Releases Ford Bronco Trail Sight Delete DRL Kit w/ Sequential Turn Signal and RGB Accenting QTE1199! 1199_Trail_Delete-08-6G
Ford Bronco Quake LED Releases Ford Bronco Trail Sight Delete DRL Kit w/ Sequential Turn Signal and RGB Accenting QTE1199! 1199_Trail_Delete-09-6G
Lèòn
Jersey
Tough, it looks sick, but I like the trail sights
still, solid and might consider it on the future builds
Hkak45
K
Illinois
21 Bronco Black Diamond
They should make a trail sight light that isn't a delete too! Cool to have the turn signal and lights on the standard looking trail sight
Bud2020
FL
Badsquatch 2.7 Lux
Neat. 👍🏼
Lèòn
Jersey
NOW we’re talking!
Lèòn
Jersey
@Quake LED , can you work in the same kit but with the trail sights?
broncobase1
Lincoln
22 Bronco Base
These are cool, but like a lot of commenters here I like the trail sights. They remind me of my first car, a 67 Dodge that had rear facing turn signal lights on top of the fenders, something I always liked about that car. On Bronco, the trail sights are a signature feature. Still I'm sure they will get takers.
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Would also like a variant that’s based off of the OEM trail sight - this is super cool, though!
broncobase1
Lincoln
22 Bronco Base
" 2021+ Ford Bronco with Factory Halogen Headlights (Base Tier) "
This is incorrect. All Broncos including the Base have factory LED headlights. I have one of the cheapest Broncos you can get, and honestly I'm blown away how much much stuff it has.
Lèòn
Jersey
