Status
Not open for further replies.
AGSOFFROAD
New England
agsoffroad.com
Introducing our newly designed ARB Twin Compressor mount- the best way to mount your ARB Twin Compressor to your Bronco.
Using the AGS Off-Road Air-Gate Kit, make use of wasted space on your vehicle and easily mount your compressor inside of the spare tire carrier. Keep your compressor away from the hot engine bay and have easy access to your air hookup without opening the hood. The mount is easily installed without drilling, cutting, or disturbing critical factory components.
With the optional AGS Filter Relocation Kit, keep the elements out and pull only cool, clean air from the interior of the vehicle for worry free off-roading.
Click HERE to check out the AGS Off-Road Air-Gate Kit and all of its contents.
************All products and details can be found on our website. Now shipping! Use promo code "bronco6g" for FREE SHIPPING on orders over $300*****************
Installation Video Here
Ford Bronco The best way to mount your ARB Twin Compressor - from AGS Off-Road IMG_3516
Ford Bronco The best way to mount your ARB Twin Compressor - from AGS Off-Road IMG_3519
Ford Bronco The best way to mount your ARB Twin Compressor - from AGS Off-Road IMG_3524
Ford Bronco The best way to mount your ARB Twin Compressor - from AGS Off-Road IMG_3499
Ford Bronco The best way to mount your ARB Twin Compressor - from AGS Off-Road IMG_3497
Ford Bronco The best way to mount your ARB Twin Compressor - from AGS Off-Road IMG_3513
OtisFE
Otis
Palm Coast FL
2022 Bronco OBX
I know it's not a part of the kit, but how did your run the wiring for the compressor? I have the aux switches if that makes any difference.
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
Love it! nice work great to see creative solutions coming to market.
Fubl
MARYLAND
01 buick lesabre
color me super intrested
  • Like
Reactions: jxc
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
Looks spiffy. But my twin arb needed two runs of 8(?) awg positive shots, plus a good ground, and another ground run that the instructions call for direct battery grounding. Easily doable, but a bit more work than the hood mount.
AGSOFFROAD
AGSOFFROAD
New England
agsoffroad.com
Thanks for the question. To wire the compressors on our test vehicles, all we did was extended the harness supplied by ARB to reach the batteries under the hood. The easiest way we found to use the factory Upfitter switches and not the ARB toggle switch is to utilize the pre-ran wire located in the right rear quarter panel of vehicle. There is a good write-up on this forum that I will link below explaining how to wire the AUX switches properly. Once you have switched power on the wire in the rear quarter panel, we connected that to the purple wire of the 3-wire connector on the ARB harness.
https://www.bronco6g.com/forum/thre...tches-wiring-diagram-video-discussions.13485/
You can also choose to use the ARB supplied toggle switch and skip the Bronco AUX switch.
There will be detailed instructions included in the kit.
Thanks,
AGS Off-Road
Edit: This is another very simple option offered by another company to extended ARB's supplied 6' harness. We recommend using this if you are not comfortable making your own.
https://expeditionessentials.com/pr...tsiOhTPOeK0xziXzE8UV0d1iZ16ufFcMaAumEEALw_wcB
Raptor911
Raptor911
Broadlands, VA
That section where you mounted the compressor is a vent that allows air to escape the cabin when you shut any door. Is it still venting?
Also, if you are running an aftermerket wheel, it may not clear the air vavle.
AGSOFFROAD
AGSOFFROAD
New England
agsoffroad.com
The mount spaces the compressor away from the cabin vents enough to not affect the movement of the flaps. Even with the Modular Tailgate Pass-Through installed there was no noticeable changes in cabin pressure relief.
We can not guarantee fitment of the air chuck on all aftermarket wheels, but the mount allows for a lot of adjustment.
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
If aux switch wiring is easy enough, I'm super interested. I'd been leaning towards a single in the cargo underfloor with AAL's rack, but that wiring and coupling seemed super daunting.
Since it's no drill, wondering if it's safe to assume compatible with most wheel relocations and hinge reinforcement.
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
What's the vertical slot on the top left side of the bracket use for?
AGSOFFROAD
AGSOFFROAD
New England
agsoffroad.com
We assume it will bolt up but do not recommend using any of our products in conjunction with other after market accessories because we have not tested it in that configuration.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
how did you route the cables going to the battery?
through the door, then through the hinge area?
Status
