Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Jeep LJ, Ford Ranger, Ford Bronco
Ford Bronco Increase Your Ford’s Bronco Traction Off-Road With ARB Air Locker EAallrMbc-dueBPOULsJaGhDfUaON8wfwMyZuUbeOraHsnexh2
The world’s premier traction aid for the Ford Bronco is here. ARB is proud to introduce the Air Locker for the M220 rear axle.
Providing instant grip at the flip of a switch by preventing the internal differential gears from rotating and therefore preventing the axle shafts from spinning independently of each other. Without it, the factory open differential only sends power to the tire without traction; but in reality, the tire that needs power is the one that has traction. This system is great for on-road driving but disastrous when off-road, making the selectable locking differential the ideal choice for most four-wheelers.
Why Air Locker?
The original Air Locker was developed in the 1980s. This design featured a three-piece case with an air actuated cast piston. A true, revolutionary piece of 4WD equipment for its time.
But as time has passed, the sport of off-roading has evolved exponentially. Large tires and engines in that era do not compare to what is being used today. 37” and 40” tall tires have become the popular choice. V8 engine swaps outputting over 500 horsepower are no longer few and far between.
To get ahead of the curve, ARB’s team of engineers were tasked with developing an Air Locker that would hold up to the future of four wheeling. The research and development consisted of many torque and failure tests on the Air Locker and other lockers. At the beginning of the 21st century, the new and improved Air Locker was released. It featured a two-piece design, less internal parts, forged gears, and a patented timed locking system; all of which make it the world’s strongest locking differential.
Its limits have been put to the test, not only surviving but also winning multiple Ultra4 off-road races where drivers run 43” tall tires and 1000+ HP.
Many of our competitors still use the old three-piece case design that we manufactured in the 19th century.
Ford Bronco Increase Your Ford’s Bronco Traction Off-Road With ARB Air Locker PxpJQXsibWBTJSdL7qWaicHeHz3Ou4lbfpXYSTONgjjhgC1viX
KEY FEATURES
  • Provides 100 percent traction on demand without affecting on-road drivability or driveline wear
  • Easy, convenient operation allows the user to concentrate on the terrain without leaving the comfort and safety of the driver’s seat
  • Two-piece design is ultra-durable and extremely strong – minimal moving parts, thereby ensuring maximum reliability
  • Patented ‘timed’ locking mechanism offers high strength and ultra-fast unlocking
  • Steel reinforced, elastomer bonded annular seal designed to handle the most extreme climatic temperatures
  • Includes: Air Locker differential, activation switch, solenoid valve, airline and bulkhead fitting
  • Race proven technology
  • Manufactured in Australia
  • Air compressor required for operation and optional tire inflation (sold separately)
Ford Bronco Increase Your Ford’s Bronco Traction Off-Road With ARB Air Locker t7XpUCXQ7zDsQezxrovhYrylLLy6uGs9BhQkXKkWjF-JV4Bi1g
SPECIFICATIONS
  • 32 spline axle​
  • 35.8mm [1.41”] axle shaft diameter​
  • 10 bolts on 157.8.mm [6.213”] Ring Gear Bolt Pattern​
  • 134.66mm [5.302”] Ring Gear ID​
  • 220mm [8.661”] Ring Gear OD​
  • All Ratios​
Ford Bronco Increase Your Ford’s Bronco Traction Off-Road With ARB Air Locker VcB7rXInpYqeoE6o1Te7DlF68RWNOIJrvR9wJSopu4HX1ydfJf
Air Locker Part no. RD245
MSRP: $1049.00
Availability: NOW (Contact any ARB Dealer to place the order) - https://arbusa.com/dealer-locator/
Ford Bronco Increase Your Ford’s Bronco Traction Off-Road With ARB Air Locker bronco air locker app info
GIVEAWAY (CLOSED)
To kick off the release, we are giving away a RD245 Air Locker to one of you lucky Bronco6G members!
To enter:
  • Like the OP
  • Leave a comment
  • Sign up for our newsletter
Last day for entries is September 9th, 11:59PST. The winner will be chosen randomly and will be notified in this thread.
Good luck!
*ARB will never message your directly and ask for your credit card information*
JakeC
Jake
Dearborn, MI
michiganbroncos.club
2022 Badlands
This sounds like a great aftermarket option for those that didn’t order a Bronco with a rear-locker.
Good job ARB!
[edit] If this is for the M220 rear diff, as an upgrade, can I ask how this is an improvement on the existing rear-locker? Maybe I’m missing an aspect of the product. TIA
jonesh242
Southern Cal-unicorn-ia
Cherokee Trail-Squak, YT Capra 29er & Decoy Mullet
Thanks for all the cool bits y'aller building at ARB. Odd question: If your bronco did not come with lockers, does this kit work for either front or rear? Or is their a specific kit for each?
Bronco_joe
joe
Niagara Falls. NY
This would be a great addition to my bronco. Thanks for the opportunity!
Sadams27
Spencer
San Anselmo
Ford Bronco
Im signed up!
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
Why Air Locker?
KEY FEATURES
SPECIFICATIONS
  • 32 spline axle​
  • All Ratios​
MSRP: $1049.00
GIVEAWAY
To enter:
  • Like the OP
  • Leave a comment
Good luck!
Here here
adamruiz2001
SoCal
Ford SVT Lightning
This is awesome, keep up the great work and quality!
Dmorty217
Derek
Venice FL
Camery
These are NICE!
Rivers90
Ben
Southern California
2 Door Base Sasquatch
This would work in the rear of any bronco but the raptor.
Not for the front.
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
Non Squatch lockers, the market is catching up.
Good to see it's being taking seriously.
DVAnt
Anthony
Honolulu
none
This is a huge giveaway. Thanks for doing it.
CBWAR1
CB
CA
1973 F250 Custom 4X4; Pending: Bronco
The BRaptors don't need the love?
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
Yes, Please
