4wp Bronco Wrangler 2Dr review.
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
Actually I think Ford refers to the Badlands as their most capable offroader.
Ford Bronco 4wp Bronco Wrangler 2Dr review. Screen Shot 2021-11-01 at 3.17.58 PM
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
stampede1
los angeles
f150
Although I agree that it will add a little articulation it still is not a big jump. There are plenty of videos with it engages the disco and the tire is still hanging in the air. There are also plenty of videos comparing these where the Badlands cannot keep the tires on the ground where the jeep does. The Wildtrack is advertised as their top of the line off roader. I think Ford did a pretty bad job with naming and advertising the Bronco and Bronco sport.
Unless I am missing something, the BL Sasq can do anything the WT can plus rock crawling, while the WT is not a rock crawler per se. And the tech specs/equipment of the FE and BL Sasq for off roaring, are the same. So not only is the WT subordinate to BL for overall technical driving, the BL is tied with the FE for such off road driving equipment and abilities.
