4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
NOW SHIPPING
https://www.4x4truckleds.com/kr-off-road-fishing-rod-holder-for-2021-ford-bronco
Check out this new product coming from KR Off-Road.
If you're a fisherman looking for a place to mount your fishing poles, look no further! Designed here on Long Island, NY (surf fishing capital of the world) this mounting system provides a simple and elegant solution to a common problem. That problem... Where do you mount your fishing poles on the Bronco?
Utilizing the existing mounting points on the front of the truck our stainless steel bracket system provides a secure and stable system to support 1 or 2 rods (per side). Each holder is designed to safely and securely hold your fishing pole without damaging it. The built in angle of the mounting system allows you to transport long fishing rods without the fear of snagging an over-pass or electrical line. The rods sit at an angle hovering over the roof line.
Simply bolt on the system, slide in your fishing pole and head to your favorite fishing spot.
The single kit allows you to install the fishing rod holder on either the driver side or passenger side. You have the option to install the system on the outside or inside as well. Keep in mind that installation on the inside of the factory limb risers will prohibit the hood from opening with the system installed.
The double kit includes two (2) rod holders (along with 2 brackets) and installs on either the driver side or passenger side. The two rod holders mount back to back. This will prohibit the hood from opening with the system installed (you'll need to unbolt it if you need to open the hood). You may also opt to split the two holders and have 1 on the driver side and 1 on the passenger side as well. We've provided sufficient hardware in the kit if you want to separate the two.
FEATURES
  • .125" #304 Stainless Steel Bracket
  • Nylon/Acrylonitrile Butadiene Styrene Fishing Pole Holder
  • Powder Coated Black Finish
  • Designed & Manufactured in the USA
INCLUDES
  • 1 or 2 KR Off-Road Brackets
  • 1 or 2 Fishing Pole Holders
  • Mounting Hardware
  • Instructions
FITMENT
  • 2021+ Ford Bronco
WARRANTY
Lifetime Warranty for the original owner.
(Photos shown may differ slightly based on final product. The final product may be thicker stainless steel or aluminum).
Ford Bronco Fishing Rod Holder Solution from KR Off-Road | NOW SHIPPING New2
Ford Bronco Fishing Rod Holder Solution from KR Off-Road | NOW SHIPPING New1
Ford Bronco Fishing Rod Holder Solution from KR Off-Road | NOW SHIPPING Rod2
Ford Bronco Fishing Rod Holder Solution from KR Off-Road | NOW SHIPPING Rod4
TBroncski
Tybor
FJ Cruiser
Subbed! Great idea.
SZairborne
Shayne
Minnesota
2018 Dodge charger GT AWD
That is awesome!!! Way to think outside the box!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Thanks. I honestly just needed a solution for myself. But realized it's a common issue. max of 4 rods but I'll work on a larger system to support more, as well as a system that mounts 2 of them on the outside so you could still open the hood.
SZairborne
Shayne
Minnesota
I'm in Minnesota and some musky rods are 8 feet and longer. They are mostly a one piece rod. This would work for those. Is there a quick disconnect to take the holder on and off, while leaving the mounting point?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I was pissed a few weeks ago. I got this nice 1 piece rod a year or two ago that i've honestly not had a chance to use. I took a break from surf casting. Got the bronco, built it up and went "hell yeah now I can hit the beach again" and said "ahhh crap where am I gonna mount this 1 piece rod"
Thought about strapping it to the spare tire but it would sit up high, and I have concerns over hitting the lines at my shop (normal street lines no problem, at my shop though it dips low when it goes into the building above the garage door).
Soo yeah, now I'll be able to use that 1 piece rod I got.
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
This is why I bought both my surf rods as 2 piece designes. But they are still long as hell. LOL. I would condiser buying these for sure. they appear to be a great design. Good work.
helifino16
Ron
Mount Sinai, NY (Long Island)
@4x4TruckLEDs.com You mentioned these last weekend. The pictures really make it look much more appealing. Since the typical LI Parks Beach Pass is a fishing pass, having a visible place to display Fishing Rods will make it easy to take the Bronco out on the Beach. Very cool!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Interested in removability and hood functionality. Watching.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Limited when you run a dual mount. So you can't open the hood with the dual mount installed (but it's easy to remove it).
If you just do a single per side, then you have no issues opening the hood. It's just when you mount 2 is all.
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Have a feeling this will be very popular with us gulf coasters
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I hope so. I mean at the end of the day there's not a lot of profits on this. BUT if we can help solve a problem we're all for that.
"Come for the fishing rod holder, stay for the lights" :)
vrtical
Doug AI
GSMNP, TN
Fords
alternative usage for bottle rockets :)
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Nice work
TNcoupe
Decatur,TN
2022 Badlands, 2023 BD, 1969 F100, 1955 T Bird
Got my River Quiver for my fly rods and its damn near longer than my 2dr.
Ford Bronco Fishing Rod Holder Solution from KR Off-Road | NOW SHIPPING 20220409_164453
