AZMikeL
AZ
Thought I'd post a couple of hacks that I've done to change some annoying things on the bronco. Anyone else have any?
AZMikeL
AZMikeL
AZ
Disable the double honk when exiting with the engine running
  • Make sure Bronco is off and at rest
  • Hold lock and unlock buttons down on the key fob 3 seconds until lights blink twice
  • Release both buttons
  • Press lock button
No more stupid double honk!
Update on the double honk. It still does do it when I close the door. I could have sworn that I tested that the other day. I guess this goes forscan bin 😬
AZMikeL
AZMikeL
AZ
Disable seatbelt alarm (because who wants to hear ding, ding in their driveway?)
  • Make sure the Bronco is off and at rest
  • Turn ignition on into accessory mode (do not start the engine)
  • Wait 5 or more seconds and clear any warnings/messages on the screen
  • Buckle and unbuckle the seat you want to disable 4 times at a 'moderate' speed
  • Seatbelt warning light should illuminate
  • Buckle and unbuckle one more time - seatbelt light should blink
Some notes:
  • The last 3 steps all need to be completed in 30 seconds or less
  • This comes from the supplimental owners guide Page 23. However, it forgot to mention clearing any alerts/warnings prior to starting the buckle/unbuckle sequence (see part in italics above)
  • Repeat procedure for all seats you want to disable
  • Use the same procedure to toggle the warning back on
For now, I've only disabled the fronts to make sure the kid is buckled up when in the back, but it's supposed to work for all seats.
Bronco VI
17 F150 Raptor/21 Bronco FE/22 Bronco Raptor
  • Press lock button
You, sir, are my hero. I have been too lazy to do FORSCAN, but I despise that stupid double honk. Thank you!
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
  • Press lock button
AZMikeL - You ever make to Central Ohio beers on me (and my neighbors) who don't have to think I am trying to get attention every time I pull out of the garage and run back into the house.
Headsong
Dude! Will these last? I mean, you don't have to do this each time you start?
Can you make the annoying "welcome" to Ford buling buling buling.... thing go away on start up? Can't stand that.
TexAg2010
Midland, Tx
  • Press lock button
Does this work on newer model F-150's as well?
Go Devils
Reed
Anything for that annoying “door ajar” ding?
amccue90
Andrew
Illinois
2021 Badlands
that one was the second one i removed with forscan, its terrible
Go Devils
Reed
AZMike will never have to pay for another beer!
BRBlue
Houston
Toyota Tundra
  • Press lock button
Doesn’t work. You got me!
Headsong
Wait, are you my dude soon to be friend in Plainfield? I had a guy reach out that he'd be happy to Forscan fix mine, if it ever comes.....in my bookmarks somewhere. I'm in St. Charles.
