- Jeanette
- Sep 25, 2022
- 25
- 242
- 154
- Mid-Michigan
- Bronco
- Raptor
I recently traded in my 4-door Badlands Sas for a Raptor and need to find some new ways of mounting some of my gear. I was using the Desert Does It 3-sided molle panels that mount to the rear roll bar for my first aid kit, fire extinquisher and shovel, but with the additional roll bar brace on the Raptor, that same solution won't work. I'm considering a molle panel that fits below the roll bar that will give me some mounting surface for some of the same items.
Can I get feedback on molle panels for that area, for a four door with a hard top that doesn't use the hard top mounting bolts (so that I don't have to worry about re-aligning the panel mounting hardware when I remove/reinstall the top) but still allow access to the hard top mounting bolts for removal (I'm using the RockWorkx hard top screws, so a bit easier to remove, but still to have access to them).
Or feedback from folks that have a similar set up that uses the hard top bolts in regards to how it has worked to remove and reinstall the hard top? Maybe I'm trying to fix a problem that really isn't a problem.
