Sold: North Carolina 4 door Packhorse Slider tray
broadicustomworks
Hanging Rock, North Carolina
This is the tray version with the open rear which to me is a lot more user-friendly.
Comes with the upgraded HD slides.
It is in OD green epoxy primer.
Works great.
Located in NC near the triad (Gbo, Winston, High Point).
Can deliver within a reasonable distance (1-2 hours).
I guess it could be shippable, but that is going to be expensive.
$400.
https://www.wickedrelicsoffroad.com/product-page/overland-sliding-cargo-system
Ford Bronco 4 door Packhorse Slider tray IMG_4998
Ford Bronco 4 door Packhorse Slider tray IMG_4995
Ford Bronco 4 door Packhorse Slider tray IMG_4996
Ford Bronco 4 door Packhorse Slider tray IMG_4994
broadicustomworks
broadicustomworks
Bump. Price drop to 3-fiddy.
Come and get it so you too can slide in style at the campground, access that Dometic for some cold refreshment with ease, or load up those cases of water from Costco/Sams with blissful ease and comfort.
It would even work with cinderblocks, deer carcasses, or a bunch of pickle jars. No judgement here.
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
So I have installed the upper and lower Molle panels in the trunk area I purchased from Broaddict some time ago. Do you think the tray will fit back there. I also have a swing gate table from Broaddict installed.
broadicustomworks
broadicustomworks
It should. There’s space on both sides.
It doesn’t fit snug against the side panels like the Broaddict slide table does.
You may have to modify the side Molle mounts some, as they share the lower mounts probably with the slider base where those factory tie-downs were.
broadicustomworks
broadicustomworks
Bump. Reduction to $300.
broadicustomworks
broadicustomworks
Bump.
Need to sell but I'm at bottom dollar on it.
less than 1/4 new cost.
broadicustomworks
broadicustomworks
I will take it for $300 if you could meet in Statesville?
I can and will.
I am free every afternoon this week, could be in Statesville by about 5pm.
Busy this weekend (will be in Wytheville, VA at the SW VA Bronco event (you should come if you don't have plans, and I can bring it with me).
Just let me know.
