35" or close+ Non E rating tires? Anything Decent exist?
BroncoAZ
Mitch
BroncoAZ
Mitch
I haven't done an extensive search yet, but several of the tires I'm clicking on (looking for something in the 33" to 34" range) are speced as E rated. Especially this sized 34" tire: 285/75R17. The options for C rated seem more limited unfortunately.
Not to mention WTH, tire prices have gotten ridiculous. My last set of 31" A/T tires cost me around $75 each on a typical Memorial Day tire sale (pre-COVID).
I did an exhaustive search last spring and ended up with the Toyo Open Country AT3 in 285/75R17 C load. I’m happy with the decision. They handle well on/off road, aren’t noisy, and didn’t submarine my MPG.
Ford Bronco 35" or close+ Non E rating tires?  Anything Decent exist? 3E28B1B2-C5CB-418B-8806-B171D8F824DF
Raptor911
Raptor911
Broadlands, VA
DrewBronc21
New York
2020 Subaru STi, 2024 M2
I have 5 of these stacked in my dining room waiting for install - heard good things, curious to see how the noise compares to the stock BD tires. They look properly chonky, that’s for sure.
You must live alone because surely your whole house reeks of tires.
Hedrock
Rome
4dr EG Black Diamond
My wife is actually, literally, a goddess.
Also it’s really just that one room. Doesn’t even bleed Into the kitchen. My sense of smell is trashed, but hers is very good and she hasn’t complained at all.
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
I was going to get the nitto ridge grappler, but I also wanted a C rated tire. I know these trucks are never going to get good gas mileage, but my needs wont require an E rated tire no sense in adding unnecessary weight. Bumping up the factory ko2 33's to 35's
DrewBronc21
New York
I bought 35” K02s and had some extreme vibration at highway speeds. Took it to a road force balance shop and they couldn’t get them to balance and had 2 shops tell me they are notorious for that. Both shops recommended Ridge Grapplers but I was hesitant due to the aggressive tread and E Rating. I ended up returning the K02s to tire rack and going with the Ridge Grapplers , balanced perfectly, no vibration and smooth ride even 80+ mph. I couldn’t tell a difference in ride quality C vs E and already have about 10k miles on my Bronco, lots of highway trips.
MnLakeBum
MN and FL
‘18 Range Rover Diesel
Toyo ATIIIs have a 35/12.50/17 with a C rating.
Nothing wrong with an E rated tire. For the most part people put way too much air pressure in the tires for such a light vehicle. I run 32/30psi with an E rated 37 on my 4-door V6 and it rides great!
Agreed. I run E rated 315/70R17 Wildpeaks at about the same psi and they ride great on the highway and are fantastic in snow and for the mostly moderate off roading I do.
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
I have 35 cooper discoverers load E. Load E tires on bronco imo are fine,air pressure less and ride is great. I run mine at 25psi. Did chalk test and was perfect. Had these tires on another vehicle too. No noise or hum. Lasted 60k on my f350. I couldnt find any load C that I liked. Air pressure is key or you will knock your teeth out. Lol
huey
kevin
Ontario & Kentucky
welp....will update once they get installed this week! From researching on this forum it seems the Ko2's and the ridge grapplers are pretty popular picks.
lonepalm
Paul
Hyde Park, NY
22 Black Diamond, 23 Big Bend
I picked up a set of the new hybrid Falken Wildpeak RT's, 285/75/17 load range C. The 35x11.50 also comes in a C range. Road noise is minimal and so far I like the handling on and off road.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Completely agree with you. That is the reason I ended up going with badlands non sasquatch, because I wanted the ko2's, even if they were 33's.
A few months back on OfferUp I scored a set of 5 F150 raptor wheels/tires with the factory 315/70/17 ko2's. $1600 with 800 highway miles on them. I sold the wheels for $1000, so I'm into it $600 for my 5 tires. I'm putting them on sometime in the next 2 weeks.
I'm in southern California and there is an abundance of raptor take offs available as they almost immediately go aftermarket with 37's. Lots of these guys could care less how much they get for them,just want them gone. I'm hoping the same may soon be true with the 37's from the braptors.
I actually think the Territory MT's are better than the KO2's, at least on ice and snow, very surprised and happy!
BroncoAZ
Mitch
66.4 pounds for the 285/75R17 and 67.5 pounds for the 35x11.5R17 seems excessively heavy on the C load rated models. I’m not sure why Falken are consistently heavier than other brands. The Kenda are 66 pounds in the 35x10.5R17, so a similar weight.
BD6G
Everglades
IN
24 Bronco
Everglades
I have to agree that the Territory MTs have been performing exceptionally well in the ice and snow.
Aliass24
NJ
I’ve been running the new nitto recon grappler size 315/70/17 SL version and I’m more than happy with them. Running 33psi with a better and smoother ride than the goodyears.
