35 Mickey ATs vs 37 K02s ?
Lak34ers
Troy
Seattle
Are the 37K02s that much larger than 35 Mickeys? Any pics or feedback please.
Lak34ers
Lak34ers
Troy
Seattle
I just got the Mickey Thompson‘s and love them!
Do you feel installed they are quite a bit bigger than oem? They look great. I want something slightly larger than oem sas goodyears to take up a little more space after I installed 6100s.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Thank you - I'm very happy with the look and performance so far.
No, they aren't quite a bit bigger than OEM. They're about the same size; maybe slightly wider/taller but nothing crazy.
Every tire manufacturer will be slightly different, but here's an approximate comparison between OEM Goodyears and the MT's:
Ford Bronco 35 Mickey ATs vs 37 K02s ? Screenshot 2024-05-29 at 5.04.12 AM
Here's a side profile of my Bronco with the OEM Goodyears:
Ford Bronco 35 Mickey ATs vs 37 K02s ? IMG_4605
And here's a side profile of my Bronco with the MT:
Ford Bronco 35 Mickey ATs vs 37 K02s ? IMG_5265
CarbonSteel
Colorado Springs
2023 Carbonized Gray
The BFGs will be a bit taller, but not as much as you would expect and if I had to choose between them, it would be the MT's.
Here are the BFG KO2 in 37x12.50x17 in load range C that I had on a 2019 Rubicon:
Unloaded (32PSI):
Ford Bronco 35 Mickey ATs vs 37 K02s ? IMG_2818
Loaded (32 PSI):
Ford Bronco 35 Mickey ATs vs 37 K02s ? 20210809_115933
Big Boss
Outer Heaven
Bronco Big Bend
Damn those baja boss AT's look mean.
CarbonSteel
Colorado Springs
@604Bronco - off topic, but where did you get the wrap on your BL? Is that factory or?
Thanks!
604Bronco
British Columbia
www.bronco6g.com
Thanks!
Thanks - It definitely catches a lot of eyes and is one of my favourite mods on my Bronco. A local wrap shop did it for me - I also had my vehicle ceramic coated, and the wrap itself has a matte ceramic coating on it vs. the painted surface.
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
How would you compare the two on the highway? Do you notice a difference?
Thanks
jeisfoto
Jordan
3rd gen Tacoma
Not sure on your sizing question but I have been nothing but impressed with the Baja Boss ATs on my Tacoma. Will likely run them on the Bronco.
604Bronco
British Columbia
www.bronco6g.com
Thanks
From a sound perspective, I'd say I don't really notice a difference. To be fair, I have an upgraded sound system which probably helps.
The tires are heavier - I think about 20 lbs or so each. You can feel a bit of extra weight on the vehicle, but nothing I'm losing sleep over. I have the 2.7 and it still accelerates and handles awesome (IMO).
I've had no issues highway driving with these tires. Everyone I've spoken to with them have spoken very highly of them too, no matter what vehicle they're on. There's various folks on B6G running them on their Bronco as well.
CarbonSteel
Colorado Springs
Can you PM me their contact info?
TxCatalystMan
Paul
Kemah, Texas
2007 Porsche 911 CarreraS
The MT's are also almost 20lbs. per tire heavier than the Goodyears.
vrtical
Doug AI
GSMNP, TN
Fords
Thats why you just get lighter wheels cause the OEM ones are boat anchors. My MT 37s / wheel setup is only 7lbs + a corner over OEM.
