34's on BigBend stock wheels
parropski
Vic
Civic
I swapped my stock 32' for 34' Open country AT3's (285/75r17).
I think they are a good middle ground between the stock badlands tires and the sasquatch set.
It was the only 34 I could find with load range "C". I had to remove the crash bars, no rubbing with the stock wheels. Really happy with the looks and performance.
Ford Bronco 34's on BigBend stock wheels 20220115_081821
Ford Bronco 34's on BigBend stock wheels 20220115_090730
Ford Bronco 34's on BigBend stock wheels 20220115_081811
Ford Bronco 34's on BigBend stock wheels 20220115_092446
old goat
Raul
Collin Co. Texas
Chevy Colorado
NICE , im also getting a 2D BB and was wondering about tire size with stock wheels , you solved my searching for the right size , thanks.
what does the meaning /difference of load range C ? what is the load range on the stock tires ??
PS are they quiet ?
OG. ---- HPR 2D BB
Taichi
Thomas
LA, USA
2019 F150 XLT sport
Can you see the 3rd brake light good enough with this tire mounted on back without having to extend it higher?
this is the size tire i was planning on going with but someone just offered me their sas tires (only) for a good deal. so ill get the sas tires which are about a half inch taller and a inch wider then probably put a 1" or 2" level kit with it.. i havent decided.
parropski
parropski
Vic
Civic
The 3rd brake light fits with the 34s but any bigger and you will either cover/bend the light or need an extender. (there must be a cheap DIY solution)
parropski
parropski
Vic
Civic
PS are they quiet ?
OG. ---- HPR 2D BB
Hey no problem, Another 2d BB owner went 35's on stock wheels. He needed spacers.
The higher the load range, the stronger the tire (more ply's) but they harsher the ride.
It depends in your intended use, but generally C ply is best for a vehicle like a bronco/wrangler. Tire is lighter and has a better ride quality.
No excessive noise compared to the stock ones.
Hyfly
Idaho
BRONCO
Awesome! Can we get more pics?
I am planning on swapping the stock BD tires for this same size. I am planning on KO2s though.
Good to know they fit without any lift or level.
parropski
parropski
Vic
Civic
I couldn't find KO2s on this size with load range C but maybe I missed them.
Here are some more pics of the brake light and the minimum poke on the flares.
Im sure 34" is the limit for the stock brake light.
Ford Bronco 34's on BigBend stock wheels 20220117_160334
Ford Bronco 34's on BigBend stock wheels 20220117_160344
Ford Bronco 34's on BigBend stock wheels 20220117_160417
Ford Bronco 34's on BigBend stock wheels 20220117_160431
Hyfly
Idaho
BRONCO
Oh man it is beautiful! This confirms it for me. This is the size!
Yea I am having a hard time finding them also. Tirerack said they should have them in stock in march. I found some on eBay also.
peterh
ny
jeep wrangler jlu 2018
thanks for sharing this, i think this is the setup for me -
just wondering, the wheels are 18 inch, correct?
any more pics from front, rear and side from a distance enough to see the whole vehicle (both wheels at the same time) would be awesome!
parropski
parropski
Vic
Civic
Bigbend wheels, so 17".
WacoBronco
Waco
2022 Lexus GX 460, 2020 GMC Sierra AT4 (Company)
Did you have to remove crash bars?
BAUS67
redneck
Central PA
BigFootie
Wisconsin
