Status
Not open for further replies.
ASFIR 4x4
www.asfir.com
Subaru XV, Toyota Land-Cruiser
Asfir 4x4 is an Israeli based manufacturer of 4x4 accessories. With 35 years of experience and passion for off-roading, we design & develop military grade underbody armor to fit your overlanding needs!
Made out of premium aluminum it is a 100% DIY bolt-on install.
We're happy to invite you to go online and explore our protection-gear for the Bronco Wild-Trak, Outer-Banks and Bad-Lands models!
Don't forget to use bro_5 at checkout for an extra 5% discount on all BRONCO products.
* lead-times are 1-2 weeks (excluding shipping)
If you have any questions, please don't hesitate to reach out here, on Instagram, online at asfir.com or send us an email to [email protected] and our specialists will be happy to help!
Cheers,
Reut @ ASFIR
Ford Bronco Underbody aluminum skidplates and protection by ASFIR 4x4 bronco
Murraydog11
Rick
NJ
2021 2Dr Outer Banks, Jeep Cherokee
Cheers,
Reut @ ASFIR
Looks very promising. Pricey, but promising.
ASFIR 4x4
ASFIR 4x4
www.asfir.com
Wow, they look very nice. An opportunity for rust resistance plus weight savings vs. the stock steel skid plates.
YES!
ASFIR 4x4
ASFIR 4x4
www.asfir.com
ASFIR 4x4
ASFIR 4x4
www.asfir.com
R.A.N.M.J.
Rick
We still don't have specific plates for the BADLANDS model, but to give an idea, the Gearbox Skid-plate is 11 lbs (5 kg) and the Fuel Tank skid-plate is 33 lbs (15 kg).
Right, I saw how much your Fuel Tank Skid-Plate weighed. I was just curious if it was significantly less than the Fuel Tank Skid-Plate on a Badlands.
If the Badlands is coming in at 35 lbs (15.9 kg) and yours is 33 lbs (15 kg) then there isn't much incentive for me to switch my stock plates to your system.
However, if the stock plate weighs 43 lbs (19.5 kg) then it begins to justify the switch.
If it totaled up to something like -80 lbs (-36 kg) weight reduced for all the plates I'd be quick to move to your system.
I'm trying to reduce overall weight of my vehicle, skid plates, fenders, doors, top, rear seat delete, etc., I'm looking at solutions like your system to replace components.
ASFIR 4x4
ASFIR 4x4
www.asfir.com
Yeah I completely understand.
Bc the Badland arrives with a full system of steel plates we still haven't designed specific plates for it. My guess, it'll weight around the same as the ones I quoted.
I don't know how much the OEM steel plates weigh, but from our experience the difference is usually significant.
R.A.N.M.J.
Rick
Thanks! I'll follow this post and keep an eye out for updates.
PWillette
Parrie
Maine
I haven't heard much on the OEM bash plate weights or durability but I hear they are thin, not heavy duty...I won't take delivery of my BL for a couple weeks so I cannot confirm. I've had the ASFIR skids on my Rover and can confirm that they are very stout and well built.
Murraydog11
Rick
NJ
Cheers,
Reut @ ASFIR
When will you have them for 2 doors?
BroncoAZ
Mitch
Looks like a good product offering. I will point out that if one is heavily into rock crawling aluminum doesn’t slide over rocks as well as steel, but for everything else aluminum is superior in my mind. Living in a salty area I would choose these to avoid rust. I’ll be curious to see the 2 door Badlands offerings.
ASFIR 4x4
ASFIR 4x4
www.asfir.com
ASFIR 4x4
ASFIR 4x4
www.asfir.com
Thanks!
Status
