30” Rough country light bar mounted to bumper.
denright17
Danny
2022 Bronco / 2020 F150
denright17
denright17
Danny
I think I might just order their 30 inch light bar… looks great. Thanks for the tip.
frkrican2004
freddy
New York
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Has anyone bought this light bar and mounted it to their bumper? Any pics would be great. Also, did you make your own brackets or buy them somewhere? I have the black series cube lights with the amber drl and want the bar to match. Tying to see if I can make it work…
https://www.roughcountry.com/30-inch-curved-led-light-bar-72930blkdrla.html
If you want a good/solid kit, go with this kit: https://www.4x4truckleds.com/kr-off-road-30-light-bar-bumper-mount-for-2021-ford-bronco/
The brackets are made here in the USA from stainless steel. The kit works WITH or WITHOUT a safari bar and it's pretty much plug and play. VERY easy to install.
The Rough Country will be less $$ but they that kit doesn't fit on the bronco without modification or drilling. It's not designed for the Bronco.
If you want an even better kit with a curved bar, check out the Baja Designs 40" Arc Kit here: https://www.4x4truckleds.com/kr-off-road-30-42-light-bar-bumper-mount-for-2021-ford-bronco/
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com has a mounting bracket for a 30" light bar but not sure if compatable with RC.
Not 100% sure if it'll fit. We tested our kits on Diode Dynamics, Baja Designs and Rigid Industries SR-Series.
They are designed for SLIM style bars, not a dual row bar.
Our 30"-42" bars are more universal though and should work just fine: https://www.4x4truckleds.com/kr-off-road-30-42-light-bar-bumper-mount-for-2021-ford-bronco/
As the 30" - 42" bar brackets we made were designed for single OR double row bars (curved and straight).
