2DR Suspension on 4DR?
Palooza
Liam
Maryland
Bronco 4dr
I just found a great deal on some takeoff Sasquatch suspension but it’s coming off of a 2DR Badlands. I have a 4DR Big Bend, my immediate thought is that it wouldn’t be quite compatible just because of the differences in weight and other factors between a 2DR and a 4DR. Wondering if anyone has had experience with this and knows if they might work out just fine.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
It’ll be undersprung - specifically the rear.
Each bronco has its own valving and spring rate based on 2DR vs 4dr, 2.3L vs 2.7L, Mt vs Auto, Tow vs No Tow…
if you were to swap in some Eibach springs (equivalent enough but soft), a perch collar or …. Ah shit, I’m drawing a blank, but there is another company offering an uprated/HD spring… anyways, what Im trying to get at is, if they are inexpensive take offs, it might be worth putting the right set of coils on them
FleshTuxedo
A
PA
'22 OBX 2dr.
Tow vs no tow has different suspension?
Palooza
Palooza
Liam
Maryland
Bronco 4dr
PWillette
Parrie
Maine
As I understand it tow vs. no tow does not necessarily correlate to different suspensions across all models...all models & door configurations have the same tow rating whether or not you order tow from the factory. The cookbook lists what is compatible. Many, many have installed aftermarket tow such as CURT on non-factory tow trucks w/o issue.
