23 Wildtrak mudflap
F150Bronco
Got the Wildtrak day before. Driving in rain in Houston not only made the Blue Bronco dirty, but our clothes too. Mudflaps are ridiculously expensive for Bronco.
I have looked at Mabett (need to unclip plastic), Rokblokz (expensive), Weathertech (front flap looks weird), Rek Gen (expensive), Gatorbacks (Hella expensive).
Is anything cheap, effective and nice out there?
Area51BS
Ron
Badlands non SAS 4dr 2.3
The 4 piece set is currently sold out. They have the front set and pic shows what look like OEM steps
JackTripper
The Beach
Enough
Got them. They seem to be cheap, effective. Do you know if I should get “extenders”?
I did not. I like the way it works. It looks like it came from the factory. The extenders look really weird and abnormal.
F150Bronco
They look perfect and cheaper than any other option. Thank you!!!
da_jokker
Jeep Wrangler JKUR
Just installed these on my WT. Only focused on the fronts. Personally I decided not to have them go down as low as I could have because of off-roading. I know they won't be as effective, but I basically have them set the same height as the bottom of my rock rails.
Use three of the inside fender well holes with some black tree fasteners I had leftover from something on my Jeep.
Universal Basic Mud Flaps Set Black https://www.amazon.com/dp/B08QHXK8Z5
You get four of them in case you mess up @ $20 :)
Ford Bronco 23 Wildtrak mudflap 20230108_071822
Ford Bronco 23 Wildtrak mudflap 20230108_071836
Snowdogyyz
23 Ford Bronco Wildtrak
I bought the fronts from IAG. Easy install and look great. I had bought and installed gatorbacks in my previous badlands and not only were they super expensive but also a major pita to install.
Ford Bronco 23 Wildtrak mudflap 47043048-3D07-49C5-93B8-5A9035ED1A30
Ford Bronco 23 Wildtrak mudflap C92105A7-0BC4-4328-A074-84A3FC2D63F8
