210 drive unit swap from 190
Little Foot
Little Foot
Buffalo
non-SAS Badlands
I'm going through the upgrades right now with my Big Bend. Mine came factory with a 3.37 open diff :poop:. I didnt pay a market adjustment so Im ok with adding these parts after the fact and not financing the additional cost, market adjustment, etc. Yes, the labor will not be cheap, but as an Army leader of mine once said, "this is my cat and I'm the one f*ckin it."
I purchased the M210 diff, both half shafts, new axle nuts, and the front driveshaft. Sourced a takeoff 4.70 locking diff on ebay from a parted-out Bronco. For the rear axle upgrade, I bought the diff install kit from Ford Performance and a new 4.70 ring and pinion set.
I already have the calibration module and found the option in the menu for gearing changes when I installed the performance tune and changed my tire size (315/70-17).
Big questions in my mind, is there a plugged-up port in my existing M220 axle housing for the wiring..? I thought about adding the full hero switch assembly, but the aux switches just make more sense to me.
I'm planning on running both front and rear lockers on upfitter switches.
I'm waiting on a response from a Ford Performance tech guy I emailed. wanted to make sure I didn't need any other components for the diff swap on the M220 besides the install kit.
Awesome. I’m really digging that so many people are upgrading their rigs. Now Ford just has to catch up with their Performance Parts that they are offering to complete the whole package 😁
SickUnit
Kurt
PA
2022 Bronco
For those of you who've installed the 210 FDU and half-shafts, must the front driveshaft be upgraded, as well?
CJ Pony Parts site:
"Please Note
: If you are upgrading from M190 FDU, M210 half shafts, and an M210 front driveshaft are required."
Ford Performance Site:
"When upgrading from M190 front drive unit, M-3429-BR half shafts required"
Says nothing about the front driveshaft on the Ford site.
Is the CJ site simply saying you have to purchase an M210 or am I misreading that?
Bronco_joe
joe
Niagara Falls. NY
CJ Pony Parts site:
"Please Note
I did not change front driveshaft. Early on it was put out it needed changing, then later updated. I believe somewhere on here someone said there is a difference but mine bolted up
Andreas24
Miami, FL
2022 2D Black Diamond Non- Sas
So you used the M190 half shafts?
Atoledo95
Alan
Los Angeles, CA
2022 Ford Bronco Outerbanks
I’m wondering if anyone has done this yet to. I wanted to full Dana axles but that’s $14k. This option is half the price so I will be doing this method to just I will be doing the Dana axle shafts for more strength.
kodiakisland
Arkansas
Yes, lots of people have done this already. I too wanted the Dana upgrade, but finally admitted to myself that it wasn't in the budget. I wont be getting everything I wanted, but will still be getting lower gears, front locker, and a stronger front axle. For half the price. It also leaves money in the budget for upgrading to the 3.0 steering rack at the same time.
I'll be going from 4.46 with only rear locker to 4.70 with front and rear locker.
If buying new, Lethal Performance makes it easy: Lethal Performance M190 to M210/220 Conversion (2021+ Bronco)
I'm hoping to get some take off 4.70 axles at a much lower price.
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
Am I missing something, or can't you just swap the whole differential in the rear (assuming you have a bronco with the welded ring gear)?
kodiakisland
Arkansas
I don't know if the housing is different with or without the e-locker on the M220. If the housings are the same, you could buy the elocker and new ring and pinion and install, but if paying someone, it's probably a wash.
It would be slightly cheaper for me to just buy new ring and pinion for the rear, but I would be paying someone to install. As it is, just replacing the whole axle gives me a set of axles with 4.46 and rear locker that I can hopefully sell to someone with a Base trim and make back some of the expense.
skyhunter
MA
2024 2DR Bronco
Be nice if there were Bronco versions of the Yenko and Nickey type dealers back in the day. I throw money and lot better than throw wrenches.
