21 Badlands Trail build
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
Badlands with 2.7 auto. Sasquatch package.
3” Body lift
4wp coil overs adjusted to 1” lift
4wp upper control arms
35x12.5r16 TSL Boggers
Black Rhino armory wheels -12
Update, (added 37x13.50r17 Cooper SST on RTR wheels
0 off set. )
JCR front bar
Bronco buster steering upgrade Flowmaster outlaw exhaust
Pedal commander throttle
Ford Bronco 21 Badlands Trail build D026192D-8E24-42D3-A0EB-5E84AD2D89C9
Ford Bronco 21 Badlands Trail build E4E0E4EE-B00C-40BD-A61D-AEB5F4269163
Ford Bronco 21 Badlands Trail build 03F4D186-9320-47FA-8463-0A9A8020E128
Ford Bronco 21 Badlands Trail build 81A2A83B-77A4-4802-86B6-A8AEAFFA1173
Ford Bronco 21 Badlands Trail build 23F90EE0-E7DF-4997-9DBF-FE1CA4C54C35
Ford Bronco 21 Badlands Trail build D929F1CD-4510-46A8-936D-812BD221E5BD
Ford Bronco 21 Badlands Trail build BA67F41F-0E19-46AA-AAB5-7F72518DBB1D
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
3” Body lift
JCR front bar
Nice build! How do you like your pedal commander? I’m thinking about getting one. I have to make left turns on busy 4-lane roads all the time and I hate not having quick response off the line, forcing me to hang out in front of fast oncoming traffic. Can you describe the difference the commander makes for immediate acceleration?
SS Bronco
SS Bronco
Shayne
Loomis CA
Thanks, It provides noticeably better acceleration in the sport and sports plus mode. It gives you zero lag, push the pedal and go. I like it because you can easily turn it on or off depending on the situation. If you leave it on in the sport mode gas mileage drops fast.
F OR D
BD Green Machine
how are the coilovers?
SS Bronco
SS Bronco
Shayne
Loomis CA
I am very happy with them. The on road ride is similar to the stock Bilstein. Off road is where they shine. No binding or popping from the suspension when flexing on rocks. Since the coil overs pivot top and bottom. The added travel is a plus. This was the first time I used 4wp, but was the only company at the time who actually had coil overs in stock.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
How bad is the "cold shake" w/the boggers? Did you use relocation brackets for your bumpers? Got any pics of body lift before bumpers were relocated? Interesting and nice build!
SS Bronco
SS Bronco
Shayne
Loomis CA
Thank you it has been fun.
The cold shake was bad this winter, now that is warm it goes away in the first mile. As you know Boggers are not good road tires, but I love them off road. I used the Broncbuster relocation brackets. They are ok, still not factory lines but a good starting point. You definitely need to raise them if not it looked weird . I have one picture from the install showing the back.
Ford Bronco 21 Badlands Trail build 208F282B-D647-4F36-8BFE-84BF4CA03BAC
Bmadda
Wisconsin USA
Thanx. My issue is I'm gonna have the winch mount installed when I lift the body, so relocating the front might not be doable. I'm only planning 2" of body lift, so relocating rear only will probably look fine. Do u remember the bolt size?
SS Bronco
SS Bronco
Shayne
Loomis CA
I would pull one off yours just to check I have herd some are different my are listed below.
2) 12mmx5.5”
6) 13mmx5.5”
Not doing the front will make it a lot easier. I had to relocate the inter cooler to realign with the front bumper. Also in the process of building a new front skid to fill in the 3” gap between bumper and stock skid.
Felix808
SRV CA
Rubicon, first trip in April then another in June.
Thought maybe. Going through the fallen trees reminded me a lot of the Dusey.
SS Bronco
SS Bronco
Shayne
Loomis CA
Upgraded the tires to 37x13.50r17 Discover STT Pro on RTR wheels
Ford Bronco 21 Badlands Trail build 0EAFA371-21B5-4921-AF3D-EA838A511DB6
Ford Bronco 21 Badlands Trail build B2054C47-2C95-437C-86F2-7B538E47E0E7
Ford Bronco 21 Badlands Trail build B3C51C53-8A50-4BFE-ACEA-DFEA7D9EB870
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
Just power brake it a bit to build boost. You'll launch like a rocket.
