2026 Big Bend BUILD :)
ryanc721
Ryan
NJ
2026 Big Bend Sasquatch
I have no B and O system. After a lot of research, ive decided on the following (and please let me know if im MISSING anything to get this done)
KIT 24 RECOIL D11700.4 COMPACT 4 CHANNEL CLASS D AMP WITH RCA SUB OUTPUT WITH PLUG & PLAY HARNESS. $500
Specifications:
RMS power @ 4 ohm (14.4V): 4 x 110W
RMS power @ 2 ohm (14.4V): 4 x 160W
RMS power @ 1ohm (14.4V): N/A
RMS power @ 4 ohm mono (14.4V): 2 x 320W
Frequency Response: 10Hz-24KHz
Signal to Noise: 85dB
Efficiency @ 4 ohm: 78%
Input Sensitivity: 0.2V-12V
High Pass Filter: 3OHz -300Hz
Low Pass Filter: 3OHz-300Hz
Fuse Rating (ATC): 50A
Dimensions (mm): 6.22″ x 5.37″ x 2.09″(158mm x 136.5mm x 53mm)
Alpine S Complete Plug & Play Speaker Bundle Upgrade | '21- Current Ford Bronco
  • (2) Alpine 2S-65 6.5" Coaxial Speakers: pre-assembled in the bracket to mount into the footwell area with connectors attached.
  • (4) (non-factory B&O) Alpine 2S-44 4" Coaxial Speakers: prepped with the breakaway tabs removed and with the connectors attached.
Bronco Subwoofer JL Audio 10TW3
ENCLOSURE ONLY- I already have the sub
Notes: I have a rocksford fosgate amp I plan to power the subwoofer with that connects through RCA with the plug and play kit.
Besides basic power wire- am i missing anything?
Thanks everyone for the guidance
