2025 Base Model to Signature Headlights
CodyFungi
Cody
Portland, OR
2025 Bronco, H1, Golf TDi
I read somewhere else on this forum the 2025 Base Model is “missing” a wire in the headlight connector which would prevent them from swapping to signature headlights. Is this true? Has anyone found a work around?
If you go with aftermarket headlights that looks similar to OEM like LED Factory or Oracle or others, do you still need to update the vehicle in ForScan?
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
If that is true, it must be something only on newer model years. I have a 21 Base and the OEM signature headlights swapped in perfectly with no FORScan changes required.
OracleLights
New Orleans, LA
www.oraclelights.com
The ORACLE Oculus Bi-LED Projector Headlights are a plug-and-play installation that uses the factory mounting points and connectors. The headlights will function normally without any FORScan programming!
