2025 Badlands Wheels nonSAS - stupid question
Tele Deluxe
Alex
Wisconsin
2025 Sienna
Good morning community!
First off, I'm sure the question has been asked a dozen times, so I'm sorry if this has already been answered. The world of wheels and tires is extremely confusing to me and usually when I get to the second or third comment I'm lost.
I have a '25 Badlands with the stock 17” Carbonized Gray-Painted Aluminum Wheels. They are just not my vibe for what this vehicle should look like in my head.
What I'm trying to accomplish is a different look without having to really do any other mods (i.e. just swap the wheels out and not change anything else). So I'm looking at Ford wheels and I'm having the hard time figuring out what my options are.
At first I was looking at these: https://www.trailreadyparts.com/sku/m-1007k-p1785e.html but the rep at one of the sites said it won't fit, I gave them my VIN and they said they don't fit 2025's, Ford support said something similar?
Then I looked at these: https://www.trailreadyparts.com/sku/m-1007k-p1785mbm.html and I'm seeing the width is different than stock, is that an issue?
And finally I looked at these: https://www.trailreadyparts.com/sku/m-1007k-p1780mbm.html and the dimensions all seem to the be the same.
So my question is - would any of these work with keeping everything else the same or just the last one?
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
All three of those will work.
That said, the first two have +30mm offsets, which is the standard factory offset for a Sasquatch tire. What this means for you as a non-Sasquatch owner is the wheel/tire might poke out slightly from the fender flare. Not enough to really matter, and frankly it's probably not worth even mentioning. But I bring it up just in case.
The Sasquatch package obviously has wider fender flares to account for wider tire and different offset.
The last one your linked has a +55mm offset, which matches your factory wheel.
Tele Deluxe
Tele Deluxe
Alex
Wisconsin
2025 Sienna
THANK YOU for that answer, straight forward and I understand it.
If i may, one more stupid question - they all would fit without needing new tires or just the last one?
Rough Rider
2018 Mustang Convertible
Those kits technically dont fit your 25MY bronco as the TPMS sensor frequency is different. Not saying you cant swap out the sensors or have them move yours over, but all Ford performance wheel kits are saying not compatible for that reason, they all Phyiscally fit though.
RagnarKon
Bryan
New England
Your factory tires will mount to all of them.
Tele Deluxe
Tele Deluxe
Alex
Wisconsin
2025 Sienna
awesome, i understand that, thank you!!
KEYSG6
Paul
2025 bronco badlands
Just switch out to the 2025 tpms sensors and all will work. First set will come with 21-24 sensors. Ford is sell my25 sensors for 290 on website. You can find cheaper. Check out steeda. It saved me 50$
Tele Deluxe
Tele Deluxe
Alex
Wisconsin
2025 Sienna
super helpful, thank you!
can they reuse sensors from my old set or naw?
ojitterr
Brent
Houston
Ford Bronco
Following this thread - Very similar situation but 2024
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
I don't have a part number but if you can find the optional beadlock capable wheels that were available on the 21 Badlands, I think you might like them.
Ducgsxr
Houston
Warbirds ‘19 scab Raptor, Italian racecars Superbikes, etc
I’ve seen where non-sas rigs like yours and mine may have to remove the intrusion bars to run certain larger tire sizes and wheel offsets. The video below shows this part, starting about the 6 minute mark.
Tele Deluxe
Tele Deluxe
Alex
Wisconsin
2025 Sienna
i think i found a photo of what you're talking about - i would agree, that's the look. the stock '25 badland wheels are so far from the promo vehicle it just doesn't look right for me. if those beadlock wheels weren't so crazy expensive that would be something i'd be looking at.
re: update on the everglade wheels, slllllllloooooooooooooooooowwwwwwwwwwww mudding. i've been talking to my dealer about this as an option and they've said " So our accessory rep got back to us and did mention that the Everglades wheels can fit a 2021-2024 but even they are unsure if it would fit the 2025. " and " My parts department had a tough time finding the answer as well and tried reaching out to our Accessory rep but they were out of town for the weekend "
every time I'm about to pull the trigger and just buy them I get some wishy-washy answer - why is this so complicated???
