2024 tow hitch install
bling229
texas
2024 Bronco OBX
Hi,
I have a 2024 Bronco and installed a aftermarket hitch assembly. Can the tow module be purchased (just the module). ?
Also to plug the factory wiring at the hitch (just the) 4/7 pin socket ?
Go_UL_Cards
Wyatt
The Villages, FL
2024 4 Door Soft-top
I bought my 4pin/7 pin from etrailer - Curt Replacement OEM USCAR Trailer Connector - Dual Connection - 7-Way RV Style and 4-Way Flat CURT Trailer Wiring C42JR $40
Trailer module can be purchased by itself - it's around $250 - $280
Then you need to make changes using Forscan to turn on the module.
Read thru this thread - it has all the details you need with part numbers. On the 2024 all the wiring is already there. The trailer control module is for the lights - it is not a brake controller. That's a separate part.
DIY Factory Tow Package using OEM parts with Forscan As-built Data (without error codes) | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
Brad
New Hampshire
2017 Ford Focus RS, 2022 Hyundai Palisade, 2001 MV Agusta F4 750
Do you have the part # for the trailer module? I looked for the part # shown in the link above, but it appears to not be valid (maybe it's been replaced by a new version?)
Go_UL_Cards
Wyatt
The Villages, FL
RoverDude is the expert on all this. Here's a link to the chat with the part number i ordered.
(2) 2024 Trailer Tow Kit (New Ford Accessory Part) | Page 13 | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
(M2DT-19H378-AB) # listed on actual part (see link below)
BUT
Fords number for ordering: M2DZ-19H332-A
Module Trailer Brake M2DZ-19H332-A | OEM Parts Online
I bought mine from my dealership using some ford points. If you look at the online link for the part is usually says "Trailer Brake" - it's not - its the light controller. The brake controller is a Redact and fits under the dash.
What I've found is the lights seems to work just fine as soon as you plug in the module. The Forscan changes turns on all the 'Tow' options in Sync4 screen.
