2023 2 door top weight?
Onestepmore
Amos
Ballwin, MO
2023 Ford Bronco Badlands with Sasquatch
Ok...so I just installed a winch in my attic that has 2 x4 trusses supporting the home roof...I'm now getting a little concerned that a may be taxing the 2 x 4 trusses with the weight of my Bronco top...I can't find anywhere how much the tops weigh...does anyone have any idea? Thanks for any thoughts on the weight and having a winch system in the ceiling to remove the top...here are some pictures of what I did...
Ford Bronco 2023 2 door top weight? IMG_2672
Ford Bronco 2023 2 door top weight? IMG_2669
Ford Bronco 2023 2 door top weight? IMG_2671
Ford Bronco 2023 2 door top weight? IMG_2668
Ford Bronco 2023 2 door top weight? IMG_2667
Ford Bronco 2023 2 door top weight? IMG_2670
Iamthedan1989
Dan
22' Bronco Base
That should be completely fine. I have used a bike hanger for mine for 2 years now without issue. Here's the weights.
Ford Bronco 2023 2 door top weight? 2021 Bronco Hard Top Soft Top weights
old goat
Raul
Collin Co. Texas
Chevy Colorado
you will be fine, back top weighs about 75-85 lbs , the two front panels weigh about 20 lbs each , total together 120lbs , maybe ?
I have the same setup except the metal iron , I bolted the hoist to my joist directly and I lift it all up with the front panels on top of the back bronco top.
using a 2x6 as the equalizer for the lift..
been doing this for two summers now.
Ford Bronco 2023 2 door top weight? IMG_1451
Ford Bronco 2023 2 door top weight? IMG_1452
Ford Bronco 2023 2 door top weight? IMG_1453
Ford Bronco 2023 2 door top weight? IMG_1445
Onestepmore
Onestepmore
Amos
Ballwin, MO
Thanks for the quick reply...and for the information!!! Amos
Onestepmore
Onestepmore
Amos
Ballwin, MO
That's Awesome!!! I was going to use straps but I like the 2x6 with the eye bolt...Nice job!!!
BigSkyBronco
Big Sky Country
'06 Wrangler Rubicon Unlimited - '96 Toyota FZJ80
@Onestepmore I like your above the ceiling solution. My experience with construction makes me think your mounting structure would be significantly more stable if you were to tie it into the trusses on the ends. Better safe than sorry 🙂
Mscdman
P
Denver
OBX
How does the hoist attach to the hard top. I need to come upwitj a solution like this
