2022 Sasquatch and Fox 2.5 Elite
ecalvo
Eduardo
Costa Rica
Ford Bronco
Hola, Im from Costa Rica and need recommendation on the best set up for my 2022 Sasquatch with Fox Coil over 2.5 Elite, for daily use , Im driving high and low DSC clicks on 7 each.
Please advice.
Gracias
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
If you have the shocks, you are your own best friend here. Not many people will be familiar with what your roads look like. Have you tried turning the compression knobs to see what the effects are?
ecalvo
ecalvo
Eduardo
Costa Rica
Ford Bronco
Hola Dangerfoot, you are right about that but I just was looking for opinions because this coilovers are not easy to understand and setup, looking for the daily setup for both roads is not easy and I haver to transit them e very day.
Gracias
Saludos
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Absolutely... suspension bracketing is the method you'd use to find what you like.
Find a section of road you're comfortable with and that is representative of your driving.
Find the compression adjuster and rebound adjuster if available. Turn rebound to the middle of the range and you'll work the compression damper. Open the damper all the way, backing the knob out. Drive the road. Notice how bumps are absorbed and how the car leans in turns, also notice how responsive steering is.
Take notes!
Now, add in some damping on the compression knobs, use a third of the available adjustment.
Repeat road test and take notes. You'll notice some bumps are not absorbed as well as before, but the car leans less in turns.
Add more damping and take a drive.
Once you have compression set to something that is comfortable for you, you can repeat the setup focusing on rebound settings.
Hope that helps!
ecalvo
ecalvo
Eduardo
Costa Rica
Ford Bronco
Thank you, I will try it.
Saludos
