2022 Bronco OBX Lux Package Window Issue
jharrell3623
NC OBX
2022 Bronco 4 Door Outer Banks 2.7L Hardtop
So we all know the window reset feature. A week ago , I remote started my bronco and once I started driving down the road , the windows did not work at all , none of them. I got to work , pulled the 10 amp fuse , checked it , good , put it back in , windows worked again. Today , I get in it , windows , none of them working. Up or down. They index correctly when I open the doors but the switches will not operate the windows , at all. I tried pulling the fuse again. Nothing , once I put it back in. So , stumped about this one , I have forscan but I have not checked any of that yet. Just wondering if anyone has had the windows stop rolling up or down. This is not a indexing problem so the reset has absolutely zero to do with it.
tobands
2022 Bronco OBX , 2024 Edge ST
Try undoing the negative on your battery let sit a few mins , kind of like rebooting system
tobands
Also had similar problem and dealer flashed my system and have not had a problem since..
jharrell3623
NC OBX
well , i went back out , started it up , windows worked , so its definitely a software issue on start up with sequencing.
tobands
at this point i would take it to the dealer and have them check it out , i know that sucks but you should be under warranty
helifino16
Ron
Mount Sinai, NY (Long Island)
Just know that this operation will/may reset anything you may have set with ForScan. Took mine back in for a 'Charging System error' and was greeted with the 'Double Honk' (ugh!) when I picked it up along with everything else I wanted to keep (lights, etc.). I had to redo it all again.
Darth_JoPa
Joshua
Bay Area, CA
2024 Bronco Badlands Sasquatch
I know this is dumb, but figured I would ask. have you double checked the window lock isn't engaged by the window buttons?
tobands
ive used forscan for about eveything i can do and never had anything revert back to original setting unhooking battery.. sounds like someone flashed your system
helifino16
Ron
I've used ForScan for about everything I can do and never had anything revert back to original setting unhooking [the] battery. Sounds like someone flashed your system.
Sorry - meant to connect my post to the one that mentioned Ford Service flashing the system to correct this issue. Unhooking the Battery would have no effect on the ForScan settings.
