2022 Bronco ignition wire
Peppered Bronco
Andrew
fontana
bronco 2022 OB
Hey, I’m trying to see how I can tap into my ignition switch wire. Does anybody have an idea which one it might be?
I’m trying to connect my switch Pro, so it doesn’t run on strictly the battery
Thank you
Valhalla
Valhalla
Chattanooga Tn
multimeter, open the fuse box, see what is switched and what isn't. Run a relay with power and switch it off this wire.
BleednBlue
Rich
Wentzville, MO
2023 Ford Bronco; 2018 4Runner; 2008 GX470
I tapped the 15amp in engine bay fuse box when installing the auxiliary switch panel sold by F150Leds.com - the have a good install video you can use to help find the exact fuse.
