2022 Bronco Headlight Issue
CG88
Cody
Georgia
2022 Bronco
My Headlights will automatically switch to "On" every 3 days. I will open my door and the lights on chime will start going off. I look at my Headlight selector switch and it will Not be illuminated. The photos below show what it looks like for me vs what it is supposed to look like. When the switch is not illuminated, the headlights will be on until I turn the switch to turn them off. When it is in this state the headlights will never turn off and the dash/infotainment system it on as well. Is there anyone having the same issue?
Ford Bronco 2022 Bronco Headlight Issue messages_0
Ford Bronco 2022 Bronco Headlight Issue d5eab049-a06d-497d-9813-d63ffdc2c077
Snappy22
2013 Honda Pilot, 2022 Bronco BD
Loose fuse? If on auto maybe the fuse for the sensor isn’t in so the headlights default to on?
do you leave it on auto headlights? I haven’t had the same issue, but have noticed that although I leave it on auto headlights, often the dash shows it is regular headlights (the A is not shown) until I toggle the switch away from and back onto the auto headlight location.
CG88
Cody
Georgia
2022 Bronco
I always keep it on auto, I never touch the knob. I do know that the Bronco's default to Auto every time you start it.
Like this morning when I first opened my door, it will chime like I had the headlights on and I haven't even been in it yet. That's when the selector switch will not be illuminated.
iwantabasebronco
No ones business
gmc
Same with me and I know one other person mentioned it somewhere. My theory is that it happens around sunset but can’t repeat this issue intentionally. Haven’t taken it in because I doubt they’ll be able to repeat it. It’s annoying….
iwantabasebronco
No ones business
gmc
I usually have to spin the dial around a bit to get it to wake up too.
Dcdds
Silver spring
03 Expedition
Does anyone know if there is a way to disable the headlights turning on automatically when starting? ( I don't keep my lights on auto)
CG88
Cody
Georgia
2022 Bronco
Yep, that's exactly how mine is. Have you changed anything at all on your Bronco? I only changed the light setting to turn off the lights 10 seconds after I get out.
TX-Hans
I recall there being some other threads over time about the headlights. Seemed like there was a group that had possessed headlight switches doing weird things like being in the on position unexpectedly or turning on in middle of the night, and there was another group that concluded they were hitting their knees against the switch causing it to change from Auto to On or other positions.
I have never looked but perhaps there might be a way in Forscan to adjust the auto headlight behavior.
Dcdds
Silver spring
03 Expedition
Thanks for the reply. I have not seen anything mentioned in the past with forscan , which I have used. But l will check again. Having the lights come on by default when starting the car is as annoying as auto start stop for me.
iwantabasebronco
No ones business
gmc
I disabled auto high beam, but it was doing this before I did that. And yeah I think I changed the timer too but can’t remember off the top of my head
aggrad2010
2022 Bronco
This happened to me the other day. Just assumed I had hit it accidentally at some point.
kfeen
Kiern
Albany, NY
2022 Bronco Base
I'm having this exact same issue so I brought it into the dealer for investigation. It turns out the headlight switch is throwing errors codes and I have an appointment for the service dept to look at it. I'll let you know!
drew707
Ford Explorer
I’ve had one instance where the headlight switch was ā€œdeadā€ as in no illumination for the current setting. I forget the code it threw but I’ll see if I can find it. Everything still functioned normally after spinning the knob and it’s never happened again.
drew707
Ford Explorer
Yes using ForScan
In the BdyCM default should be 00 change it to 01 as shown below
726-74-01 xx01 xxxx xx—
