- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
ARB Summit Bumper has been added to the site and is available now for pre-order, as always message me for forum pricing.
Frank
2021 Bronco ARB Summit Bumper ARB3480010
2021 Bronco ARB Summit Winch Bumper Features:
The 2021 Bronco ARB Summit Winch Bumper blend seamlessly into your Bronco's vehicle design and complements wide or narrow fender flares. Not only is it aesthetically pleasing, but has premium off-road protection and functionality. This bumper is compatible with winches up to 10,000lbs and accommodates adaptive cruise control and parking sensors. It also provides twin jack and rated recovery points. Be confident that this bumper will not quit on you even when you push it to its limits. This bumper also works with OE LED Fog Lights that can increase visibility beyond what your factory headlights can do. Morning, noon, and night, you will always have the advantage with the 2021 Bronco ARB Summit Bumper. You will also be pleased with the elevated look it will give your 2021 Ford Bronco with the IntegritTM black textured powder coat. Hit the trails in style and make the other 2021 Ford Bronco owners jealous. Mounts the Compatible Winch in a Feet Down Orientation
The 2021 Bronco ARB Summit Winch Bumper is compatible with winches with up to 10,000lbs of pulling capacity. Some of the available compatible models are listed below. This bumper is equipped with two reinforced high lift jacking points fitted to the center pan and is perfect for use with the ARB Jack. There are also preinstalled recovery points that are rated to 8T in a direction of pull up to the the maximum turn angle of the front wheels and are suitable for traditional 4.75T rated bow shackles or the ARB Soft Shackle. Adaptive cruise control, fog light compatibility, and parking sensors are included for greater driving assistance. Best of all, the 2021 Bronco ARB Summit Winch Bumper is crafted from durable steel and undercoated with EDP20 Ecoat for corrosion resistance and long-lasting, maximum protection.
Compatible Winches
Frank
- Compatible with winches up to 10,000lb
- Durable, steel construction for maximum protection
- Twin jack points located in lower pan to suit ARB Jack and mechanical jacks
- Twin forged bar-mounted ARB Rated 8T recovery points
- Wing design allows for a 37� tire to be fitted (suitable suspension lift and rim off set required)
- Approximate weight of the bumper, chassis mounts and fitting kit is 172lb
- Suits ARB UVP (PN 5480010) and OE Ford under panel
- Suits the use of OE LED fog lights
Compatible Winches
- 8,000lb-9,500lb Winches
- Warn VR EVO 10-S 10,000lb Winch with Synthetic Cable
- Warn VR10 10,000lb Winch with Steel Cable
- Warn Zeon 10 10,000lb Winch with Steel Cable
- Warn Zeon 10-S 10,000lb Winch with Synthetic Rope
- Warn Zeon 10 Platinum 10,000lb Winch with Steel Cable
- Warn Zeon 10-S Platinum 10,000lb Winch with Synthetic Rope
- Smittybilt Gen2 X2O Comp 10000 lbs Wireless Winch
- Smittybilt Gen2 X2O 10000 lbs Wireless Winch
- Bulldog Winch 10000lb Standard Integrated Winch w/ Wire Rope
- Bulldog Winch 10000lb Standard Integrated Winch w/ Synthetic Rope
- Rugged Ridge Trekker S10 10,000lb Winch with Synthetic Rope & Wireless Remote
- Rugged Ridge Trekker C10 10,000lb Winch with Traditional Steel Cable
- 2021 2-Door Ford Bronco
- 2021 4-Door Ford Bronco
