- Feb 21, 2020
- 112
- 7,302
- 25,630
- North Texas
- SUV
- Undecided
Several people estimated the tire, ground clearance and door handle dimensions on this thread:
https://www.bronco6g.com/forum/thre...nco-4-door-topless-2-door-in-background.1152/
They seemed close but perhaps a little bit off so I took the photo and scaled the measurements based on the Little Giant 4 step ladder in the photo, which is 35" to the top step, per the manufacturers spec. As and example, I measured the scale distance between each step and averaged those to account for the parallax in the photo, the average rise between steps is 9". I continued the process allowing for the different angles to estimate the dimensions, this is not an exact science so the there are some uncertainties in the numbers, I did the following estimates:
1) Frame Ground Clearance: ~17.5"
2) Tire Height: ~32.6"
(potentially 265/70R18, see discussion below)
3) Bolt Pattern: 6x139.7 (6x5.5)
4) Door Handle Height: ~42"
EDIT: Updated dimensions and image based on community feedback, thank you.
