20% OFF Eibach Stage 2 Suspension Lift System - In Stock
NEO Motorsport Garage
Roman
North Royalton, Ohio
www.neo-garage.com
2023 Bronco Raptor, 2022 F150 Raptor
We have a few more Eibach stage 2 systems in stock, these have been hard to keep and are a massive improvement over stock suspension while also offering an adjustable coilover system without breaking your wallet.
DETAILS
  • With consideration to the Bronco's capable chassis, it was our priority to maximize performance, ride quality and lift on all trim levels. Height adjustable threaded bodies allow you to easily dial in ride heights to fit larger tires and increase ground clearance.
    Eibach\’s in-house development and manufacturing gives us the ability to fine-tune the combination of spring and shock performance. Using progressive coil spring design, our solution delivers optimal suspension travel. In addition to as much as 4" inches of lift*, each shock features extended monotube design and variable force valving to deliver control during on-road transit and compliance for maximum traction on the trails. All made by Eibach in the USA.
    • Pre-assembled for direct bolt-on installation
    • Utilizes our ERO Championship proven Off-Road racing springs
    • Designed to work with factory control arms for an increase in height without accelerated wear to ball joints and bushings
    • Developed specifically to provide a balanced ride quality on and off-road
    • Made by Eibach in the USA
  • Included:
    2 – Front PRO-TRUCK Coilover 2.0 Shocks
    2 – Rear PRO-TRUCK Coilover 2.0 Shocks
    1 - 6mm adjustment spanner wrench & all required mounting hardware
    Ride Height:
    * heights vary per trim level, see application listing for measurements.
Part Number: E86-35-056-01-22
ModelFrontRear
2.3L Non-Sasquatch
2.7L Non-Sasquatch
Big Bend 2.3L Non-Sasquatch
Big Bend 2.7L Non-Sasquatch
Black Diamond 2.3L Non-Sasquatch
Black Diamond 2.7L Non-Sasquatch
Outer Banks 2.3L Non-Sasquatch
Outer Banks 2.7L Non-Sasquatch
+1.6 - 4.1"+2.3 - 3.8"
Badlands 2.3L Non-Sasquatch
Badlands 2.7L Non-Sasquatch
+0.9 - 3.4"+1.6 - 3.1"
Sasquatch 2.3L
Sasquatch 2.7L
Wild Track 2.7L
First Edition 2.7L
+0.5 - 3.0"+1.2 - 2.7
THE GOOD STUFF!
: Free Shipping Included
: 10% OFF use code EIBACH10
: NO LEAD TIMES :)
Order online here;
https://www.neo-garage.com/products/2021-ford-bronco-eibach-stage-2-coilover-system
PICTURES
Ford Bronco 20% OFF Eibach Stage 2 Suspension Lift System - In Stock 11D210C5-D48D-4CC0-90F0-0502C9C9C89E
Ford Bronco 20% OFF Eibach Stage 2 Suspension Lift System - In Stock 8D5A9E52-716E-4972-8521-6CF451663BA3
Please reach out with any questions!
www.neo-garage.com
[email protected]
216-834-9557
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
Do you have the shock travel numbers front and rear?
Roman
www.neo-garage.com
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Dang. That’s a great price. $1448 shipped.
kojack19
CT
Ford F150 Raptor
looks like the sale is over?
Roman
www.neo-garage.com
I ended it at the end of April - but if you’re interested send us a text and we will still hook you up!
216-834-9557
