2 dr on road stability and drivability vs 4 dr
marjen
CT
So I had been planning a 4 door but now I am leaning 2 dr. I am having some concerns though. It has a fairly short wheel base and high center of gravity. Is the 2 dr going to be a bit unstable at highway speeds? More prone to flipping? Assuming the 4 dr will have a smoother ride?
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
It will be fine. You'll get some hop from highway expansion joints because of the short wheelbase. Stability will be higher with the 4 door but won't be bad with the 2 door. I drove a CJ7 for many years with a modest lift and 33" tires. Lots on the highway. Not a big deal and its suspension was crap compared to the Bronco.
Oh and the '75 Bronco in the garage has over 200k miles, most on the highway. Drove fine for all those years and it is almost exactly the same wheelbase as the 2 door.
Austin26
Austin
Houston, Texas
2019 Subaru Crosstrek
I've thought about that as well. For my uses I'm getting a 4 door but it is pretty much certain it'll ride better and more stable at higher speeds than a 2 door. The same reason why an ATV is dangerous over 30/40mpg on hardball.
No one knows yet for the new Bronco but maybe someone here can share their experience with a similar situation on a truck perhaps of a short wheel base versus long wheel base. I've driven such but didn't notice much difference. But the short wheel base was still longer than the Broncos will be.
I will say that if you swap wheels to make sure to keep them tucked in similar to the stock wheels or you'll only be making the problem worse for a stability at speed.
I can also say that if Ford released the 2 door with some sort of death wobble or other handling deficiency, it could nearly kill the model despite the popularity. That being said I think there's a 2% chance something like that will happen for obvious reasons!
Quicklime
Lane County
Bronco Sasquatch 2 Dr hardtop
I've done extensive high speed driving on rural areas of I-5. The 2dr is a blast at speed, 80, 90, 100, it's rock solid. And remember, real Broncos didn't have four doors. The only drawback to the 2dr is the smaller 16 gallon tank.
The Beaz
Shad
San Francisco
The 4dr drives and handles very smooth, and dampens the rough roads at medium-high speed. At highway speeds, they handle about the same, though the 2dr is just a bit more rough. The 2dr handles like a go-cart on the trails, and is just a bit more zippy, much more fun to drive than the 4dr, but storage can be an issue if you need a lot of interior cargo space, or have long items, i.e. skis, poles, etc.
I have not yet ran into a situation where the 2dr felt unsafe or unstable in on-road conditions, with just over 30k miles to date.
HeliPilot
Kenny
CT
2022 2.7L SAS
I've had both in SAS packages. The 2 door has a quicker steering feel. It is a shorter wheel base, so of course you will feel the second bump quicker as it goes from front to rear wheels. But, it handles and rides as well as the 4 door. After owning many CJ's, I am blown away by how well this thing handles and rides. You will not be disappointed in either choice. I wouldn't give up my 2 door for another 4 door, period.
Bikeric
Tulsa
2022 Badlands LUX on 37's
Wife had a basic Big Bend 4-door, where as I have a Badlands 2-door. The Badlands is night and day better riding than the 4-door ever hoped to be. The Hitachi shocks just ride rougher and no extra wheelbase will fix that.
Evans67bro
Evan
Easton Maryland
2019 F250, 67Bronco,2022 BD,2023 BD
I have both the 2door and four door blackdiamond same wheels,tires ect. Only difference is one is a 2.3 the other is 2.7. They both ride well. The 4 door is a slightly better ride but dont let that stop you. If you dont need the room get the 2door.
Lèòn
Jersey
I drove to florida and back (1000 miles each way), drive all over, got almost 32k miles in 17 months and no complaints, though Id like to try the oem rear sway bar out
Even my friends with JKU’s like my 2dr over their jeeps, and again, cant compare it to a 4dr, but its solid and tossable
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I have a 2 door Badsquatch and was surprised how stable it is compared to my 2, 2 door Jeeps and was even more impressed that the 4 door I had at OffRodeo felt virtually the same.
I'm also impressed with how NOT top heavy it feels, even with my RTT!
Scott R Nelson
Meridian, ID
The two door is very stable on the highway. No issues. You can point and squirt in traffic in situations you wouldn’t do with the moredoor.
This.
I was surprised at what a good ride my 2-door Sasquatch has on the freeway. The wheelbase isn't that much shorter than on my other two cars.
And I'm pretty sure the 2-door is quite a bit easier to turn around when you end up somewhere like this with a snow drift blocking the road and you don't want to back it up for half a mile until you get to a wide spot.
Ford Bronco 2 dr on road stability and drivability vs 4 dr PXTZc84
Mikey1287
22 Bronco, 72 Mach, 03 Mach, 69 Mach, 08 Harley
The two door is very stable on the highway. No issues. You can point and squirt in traffic in situations u wouldn’t do with the moredoor.
This and you will love the turning radius!
Tex
Cliff
San Angelo
I love how people are responding to a 2.5 year old thread like OP is still making up his mind at this point
