lakesinai
Charleston SC
Well, it turned out great. Really nice job on it. I'd be hesitant to grind off the seat studs. I assume they will no longer work for holding the seats in place? Or is there enough left of them to still get the nut on there and hold the seat down? Looks like the cardboard that was on the plastic sheet was perfect for making the template. That's reason enough to consider using the plastic sheet!
What did your seadeck guy charge you for that? Just curious so I can shop prices in Houston and see if they are comparable to your guy.
Sea Dek is direct order from the factory in FL, last I used them.
