2 door grab handle lights wiring
J
Manual bronco black diamond 2 door
Hello. Any insight on how to wire 2 door grab handle lens? Please let me know. Thanks.
helifino16
Ron
Mount Sinai, NY (Long Island)
The IAG interior lights (and Mabett also) tie into the rear crossbar light with an add-on harness (not sure about '25 compatibility), but the nice feature about that is that they can be turned on and off (or disabled - if desired) with the overhead console interior light switched. Previous to this solution, they came on with a door open only by using a very specific wire under the dash. (I had my IAG lights tied into that to start and it was a PAIN to locate and connect). Given that as an option, I would recommend NOT enabling the light. The IAG crossbar connection comes as a separate component for $39 - you may be able to get that and cobble together the connection to your grab handles. I'm actually surprised that it doesn't include what is needed to connect those.
J
Cool. Thanks. To clarify there's is no rear roll bar light. Id have to use the front map light? I appreciate your time. J.
