2-door constraint lifted now?
MI_Chris
Bronco, Explorer, Edge
I have seen quite a lot of 2drs being scheduled, does that mean the constraint has been lifted?
Neigh
Houston, TX
2022 Bronco
No, that just means Ford is in the "mood" to build them right now.
TriggerTX
Trigger
Austin
61 Ford T-Bird, Autozam AZ-1, Golf R, Suburban 4x4
As long as they are still in the mood on Monday when mine is scheduled.
emulous74
Seth
Austin, TX (Pflugerville)
'19 ZR2 Bison D , '23 Bronco 2DR, MT
As with most of the constraints, they are not 100% constraints. You'll often see the constraints listed with a percentage. So if it says Lux package constraints 80% they are able to build out 20% with Lux package. (I may have those numbers switched, but you should get the point).
