buzpro
Binky
Tacoma
This thing popped up on my feed today ....
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Bought on Wednesday and delivered Friday. Very nicely made and no slop when turning it. There are no sharp edges and the o-ring on the cap is a nice touch.
@WLDTRK73
Ford Bronco 2.7L Oil Change Tips + Replacement Drain Plugs 20231223_100859
Ford Bronco 2.7L Oil Change Tips + Replacement Drain Plugs 20231223_100848
Ford Bronco 2.7L Oil Change Tips + Replacement Drain Plugs 20231223_100823
Ford Bronco 2.7L Oil Change Tips + Replacement Drain Plugs 20231223_100810
Ford Bronco 2.7L Oil Change Tips + Replacement Drain Plugs 20231223_100742
WLDTRK73
FL
2023 Azure Gray
@WLDTRK73
Never thought I would be excited to see so many o-rings on something!
Looks very well made, thank you for the pictures. Now the question is, when are you installing it?
CarbonSteel
Colorado Springs
Next OC...about 4K from now. My last UOA at 3K was good from a viscosity retention and fuel dilution perspective so I am going to go to 5K.
buzpro
Binky
Tacoma
@WLDTRK73
Better pics than their website ..... but I thought you were getting the older style without the spring washer.
CarbonSteel
Colorado Springs
Decided against that. The metal locking tabs would wear the pan over time.
  • Like
Reactions: 0ne
da_jokker
Jeep Wrangler JKUR
Just did my oil change yesterday on my 2.7. fastest and cleanest oil change of any vehicle I've owned.
I had installed the Ronin on my 1st oil change so now even with my skids, I can still reach in and twist on the hose.
The "base" part of my Ronin never comes out...just unscrew the cap, insert in the nipple release and done.
buzpro
Binky
Tacoma
word to the wise, after all the oil is drained remove the Ronin plug too ... there is more than you think that's still left in there.
  • Sad
Reactions: 0ne
da_jokker
Jeep Wrangler JKUR
I would not be surprised if there is a little bit but it can't be that much. I'm putting in at least 6+ qts afterwards to get my levels back up.
Also, I run extended oil (10k-15k) miles but change it every 5k so If there is a little bit left... I'm not worried.
The entire reason I went to a Ronin is so that I'm not wearing on those small plastic tabs in our plastic oil pans. The "base" snapped and locked into place when I first installed it..no leaks...done.
  • Like
Reactions: 0ne
buzpro
Binky
Tacoma
Per recommendation from Ronin I tilt the car when doing the oil change and after I take out the whole plug I get a little under a cup and a half of extra oil out of there.
Just mi dos centos.
  • Like
Reactions: 0ne
CarbonSteel
Colorado Springs
Just mi dos centos.
Good to know. I'll have to see how the UPR does since it should allow more to drain based upon its design.
At the same time:
1.5 cups = 12 ounces
6 quarts = 192 ounces
12/192*100 = 6.25% so not a large amount remaining.
2DR22Bronco
Chad
Seattle area
04Cobra, 95Cobra, 17Explorer, 89Bronco!!, 22Bronco
I did my second oil change recently
The thread title asks for tips so I will make the following comment of it can be a good idea to keep a spare oil filter housing on hand in case of any issues.
Reason being is I feel it can/could be pretty easy to cross thread the housing plastic oil filter housing cover when screwing it back on, especially if you have bad lighting or are maybe not on a step stool to see what you're doing easily (Especially if Sasquatch or running larger tires). Also could potentially crack the cover if it slips on you when trying to install the new o rings which is not super easy.
Thank you shout out to @Ducati0927 for posting the part # earlier in the thread
ft4z-6a832-c
Anyhow my 2 cents of long term I think these Housing covers are not going to be long lived.
0ne
Nate
CO
Flex
ft4z-6a832-c
Here’s a couple solutions, check them out:
Solution 1
Solution 2
2DR22Bronco
Chad
Seattle area
Solution 1
Solution 2
Good stuff
I think I will go MMR as the $379 for the "cannister adapter" is a bit too much $$$. Also if I had (God forbid) any Engine warranty issues I think Ford would give me grief for it.
Thanks for the info!
  • Like
Reactions: 0ne
CARdiac
Joel
Maryland
Hummer H3 Alpha, MINI Cooper S JCW, TVR 280i
My Ronin plug was working perfectly for 20K miles and has now started to leak. Has anyone else had an issue like this?
  • Wow
Reactions: 0ne
