2.7L Ford Performance Tune - How to confirm
shift9996
Victor
Palm Desert, CA
2023 Bronco Badlands Sasquatch 4dr
I've had the ford performance tune installed (By Galpin) on my '23 bronco badsas for about a year now and really love how it drives. Recently, while flooring it to get around some dangerous holiday traffic, I had the check engine light flash mid pass and the motor felt like it was now a 5 cylinder. I immediately pulled into a strip mall and shut the vehicle off. I inspected the engine bay for anything obvious and let the car sit for 30 minutes. Afterwards, I fired it back up and everything was back to normal. No check engine light and no sign of anything wrong. To be safe, I took it to my local dealer that happened to be a mile away. They confirmed that there was a cylinder 2 misfire event at the stated time without ever going out to the vehicle (kinda scary that they can do that, but I guess if the app knows they would too). They mentioned that it had since cleared, and everything was coming back green. I told them to keep it and do an inspection. The next day I get a call saying the tech inspected it and did a test ride of 10 miles. Everything looked good. I picked it up and drove it for the next week and here is where the problem lies. It might be placebo but I feel like the car shifts like stock (before the tune was installed). I also found it odd that the SA mentioned when I picked it up something about a note mentioning the tune as installed on her screen which she had never seen before. I told her I had it installed by a reputably dealer and had all the documentation and went on my way. Is there any way I can confirm that I have the tune installed still and the dealer didn't reset something accidentally? I have the Procal used to install the tune and a working FORscan setup.
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
Did your tune fix A.S.S.? If so, you could check to see if that reverted.
timhood
Tim
Several
I don't have the ProCal, but I thought you could connect it to your Bronco, and it should verify what tune is installed. I know you can also go ahead and re-install the tune if you wanted, using the ProCal. But if I was designing the device, I would have designed it so that it could report to you what the current installed tune is.
shift9996
shift9996
Victor
Palm Desert, CA
The tune did indeed fix Auto Start/Stop. It's still off so I suppose that is a good sign.
If you have the adapter still you can always reinstall - it won’t hurt anything if it is installed
I don’t recall if the adapter actually tells you if the tune is on or off though - just shows the files you can flash to the Bronco (stock, tuned, rack, etc)
shift9996
shift9996
Victor
Palm Desert, CA
I went ahead and updated the procal device and reinstalled the tune on the vehicle. It feels like I remember it now, mainly the shift points and feel. Since I couldn't find a "status" anywhere on the handheld this could all be placebo on my end.
