2.7 Engine failure, Stranded for Christmas
JHawk
Ray
Heartland, USA
Fusion Sport
2023 Bronco Wildtrak. I have owned 12 months this month with 12k miles. 2 hours from home on an 8 hour trip to see family for Christmas when a knocking noise starts but no feedback in steering wheel. Immediately pulled over and engine died. Cluster lit up like a Christmas tree (bad pun). Everything appeared ok under the truck and hood. Tried to start but it sounded horrible so I stopped. I did notice a puddle of oil under the truck when the tow truck driver arrived. I was fortunate to be about an hour from my daughter so we borrowed a car that I gave her for college and pushed on.
The truck will not get attention until after Christmas but I think I am looking at a new engine. I waited 2 years, drive it for 1 year. Sad but counting my blessings. I hope that everyone else has much better Christmas.
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
That's crazy, sorry to hear about the situation. I thought @fordmotorcompany worked out the wrinkles on the 2.7L's detonating? I guess I thought wrong.
lapazleo
2022 bronco badlands
Being there are 10s of thousands of 2.7s out there in all types of vehicles with no issues the op seems to just have bad luck.
JHawk
JHawk
Ray
Heartland, USA
Fusion Sport
I hope that it is just bad luck I do not want others to have the same experience. I am also looking forward to getting it repaired. I will update what the issue is once I know.
cbrownabq
Littleton, CO
Dodge 2500 diesel
Sweet, I have a ‘23 2.7 that JUST hit 12k…🙄
da_jokker
Jeep Wrangler JKUR
Let us know what you find. The only "known" issue was the valves way back in 2021 but that had been address.
There is nothing trending currently that would mechanically implode a 2.7.
Ozbronco
Bella Vista
2023 Badlands 4 door, 2.7 litre, cactus grey
I have a MY23 2.7 and I'm at 16.5k so 12k isn't magical for everyone.
I also have a MY23 2.7 with over 20k. I have an occasional check engine light which Ford Pass describes as "a concern with the catalytic converter". The warning then goes away. This has happened a couple of times. The dealer service cannot diagnose it because it clears by the time my service appointment comes up. May just have to demand they check it immediately if it occurs again. Other than that, all is well.
jjsgroi
New york
2018 mustang
I was a Ford dealership tech( mechanic) for over forty years own a 22 bronco 2.7 it has to be the noises engine I have ever driven
Bellime
Keith
2022 Ford Bronco
My 22 2.7L is pushing 18K. I think you just had a bad piece of luck, but we all hope your Christmas is safe and warm. Stay well, you will get through this.
LarryZiegler
Larry
I have a 2021 2.7 that was manufactured during the known trouble period. It now has 18,000+ miles and has shown no troubles. As I understand, the engine issue manifests itself early in its operating span, so I feel fortunate. As protection, I do have an 8 year/100,000 mi extended warranty in place.
MJ12
New Mexico
Dodge Charger 392
What a shame... lets us know what they find.
0ne
Nate
CO
Flex
Oil drain plug fell out maybe? Gotta twist hard till the click…some aftermarket plugs use a spring washer to establish sealing tension with concerns over vibrating loose/out. 🤷‍♂️
AZBronc24
Rich
Breckenridge MI
2014 Ram, 2010 Camaro,
Just curious, when did you do the first oil change? What filter currently, oil brand and type? Hope for the best on your situation.
TailChaser
Kentucky
2023 Bronco OB Sasquatch
Or oil filter had a leak/piece of debris allowing it to drip. Wrecked an atv engine once from that. Also had an oil change shop that’s all they do didn’t tighten something good but I noticed it soon enough. If you saw a puddle it prolly ran out of oil. That’s prolly bad news since they may deny warranty.
although it could be a rear main seal went out, or oil cooler seal maybe, not sure of the design details, and hope I never have to. So it Could be other things.
