- Dick
- Apr 12, 2021
- 88
- 7,499
- 25,647
- PNW
- Website
- www.TD-Distributing.com
- 21 Bronco, 88 Bronco II, 03 Ford F250
- Badlands
Note, just the hitch, no wiring. The below is copied from a FB post:
Here's a quick basic write-up of how to add the trailer hitch if you guys want to. We had a customer bring this to delivery, and we got it done real quick while he was signing some paperwork. It does require you to remove the spare and the rear bumper which is a very easy process.
For the bumper it is only held on by 6 bolts. Check out the picture below where we circled them. Start by removing the spare
If you are installing the hitch at this point you should have no issue seeing what happens. It has four bolts, and it's very obvious where it goes on the frame.
- There are two 15 mm hex head bolts which also hold the tow hooks on each side.
- There is one 13mm hex head bolt facing parallel to the ground on each side.
- There is an easy to release electrical connector. One side for basic rigs, one on each side for fancier rigs.
