LethalPerformance
Jared
South Florida
www.lethalperformance.com
Hey all!
We just added the 2026 MY Mirror Caps to our lineup of Painted Products.
Ford Bronco Painted Mirror Caps for 2026 Bronco NOW AVAILABLE! mirro cap sq
These direct replacement components are professionally prepped and painted to match your OE color, giving your Bronco that fresh, finished appearance that it should’ve left the factory with.
Of course, we also offer the rest of the Painted products shown, like our Door Handles, Sasquatch Fender Flares, and even emblem.
Ford Bronco Painted Mirror Caps for 2026 Bronco NOW AVAILABLE! door handle dq
Ford Bronco Painted Mirror Caps for 2026 Bronco NOW AVAILABLE! fender flare sq
Check out all of our Painted/Paint Matched products here.
Of course, if you have any questions, reach out!
Ford Bronco Painted Mirror Caps for 2026 Bronco NOW AVAILABLE! bronco harlow paint mtachjed-8
SkyKing
Boston, MA
'21 CG Wildtrak, E.R.A. Cobra 427 S/C
what's difference between this and buying replacement color matched ones from Ford (which would have come on an Outer Banks)? My 2021 Wildtrak came with black painted mirror caps.
Bigtopher
Clifton Park, NY
2025 Ford Bronco
Likely no difference other than sourcing the parts from Ford in what colors are available for those trim levels of that model year. Going aftermarket allows for more color options. My badlands is Velocity Blue and I think my only option is to have something custom painted.
dougcjohn
Doug
Iowa
‘24 F450 Limited, ‘25 Bronco Raptor, ‘16 Smart Fortwo, ZX12R
I got the Paint Matched Door Handles and Mirror Caps for my 2025 BRaptor. Very nice visual improvement... I did notice that some other models had painted mirrors. I did learn there is a unique technique to install the Door Handles... It took me several hours on the first one, then 5 minutes each on the remaining 4.
Is there a difference in 2026 Mirror caps to 2025 downward? I wasn't aware they changed in 2026.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Any part intended to be painted from the parts counter only comes in primer so there is an additional cost the buyer will have to pay. @SkyKing MY'21 WT came with shadow black painted mirror caps as they were intended to match the shadow black painted mod. top that never made it to production until years later. MY'22 WT had the painted mirror caps removed for the standard MIC-color mirror caps to match the MIC top.
Beach_Bum
Ken
St. Augustine, FL
Prior MY Broncos with the HIGH/LUX package have the integrated spotlights in the mirrors. Ford eliminated the spotlights on current MY regardless of what option package. Raptors should still have the integrated spotlights in the mirror caps - though I'm not positive as I don't track details of the Raptor.
dougcjohn
Doug
Iowa
Yes, BRaptor has the spot lights and the Wide stance side markers.
So you’re saying the new 2026 includes the spot lights again for all models or you still need to get mirror caps based on 2026 models. Which would be the same as previous years?
Beach_Bum
Ken
St. Augustine, FL
No. The integrated spotlights in the mirrors has been removed for MY'26 regardless of the options.
The color of the spotlight is immaterial to the mirror cap. But you'll need the earlier MY mirror cap for the HIGH/LUX Broncos.
I didn't view LP's website offering so hopefully they have the necessary option. Otherwise, you'll have to order the caps from the parts counter. Keep in mind that paint matched parts ordered from the parts counter doesn't come painted, but only in primer. The parts still need to be sent to the body shop for painting for an additional cost.
dougcjohn
Doug
Iowa
That was always my understanding, new parts still needed to be match painted. Several Paint shops buy the OEM parts and paint them. Not sure what Lethal Performance does; I got my door handle set through them and they looked like OEM internally too. Mirror caps I got through BFN Truck Shop. ** I removed the link ***
Both Lethal Performance and BFN do great work!
Beach_Bum
Ken
St. Augustine, FL
That was always my understanding, new parts still needed to be match painted. Several Paint shops buy the OEM parts and paint them. Not sure what Lethal Performance does; I got my door handle set through them and they looked like OEM internally too. Mirror caps I got through BFN Truck Shop. https://bfntruckshop.com/shop/ols/products/2021-ford-bronco-mirror-caps-painted-to-match
Yes, I would have mentioned BFN Truckshop but didn't want to promote another business on LP's thread. AFAIK, LP is the only one that does the painted Sasquatch flares. But the other parts can be sourced from other channels.
dougcjohn
Doug
Iowa
Gotcha... so 2026 dropped.
Color of the Spot Light? Lost me there... aren't they all the same white light if equipped?
The Raptor has additional Side Marker Lights in the Mirror cap... Forward Amber/Rear Red... for DOT Width requirements. Similar to my Dually's side marker lights.
dougcjohn
Doug
Iowa
actually, several will do the flares... your flares off rig or they acquire and paint if requested. I know 3 off hand while doing my F450 and BRaptor. LP offered nice work & price for handle set.
Beach_Bum
Ken
St. Augustine, FL
So I don't pay much attention to the Raptor details. I thought the color of the light was internal to the spotlight structure. The cutout in the mirror cap is the same regardless of a Raptor or the earlier HIGH/LUX Broncos.
If that is not the case, then there will be a specific Raptor mirror cap.
LethalPerformance
LethalPerformance
Jared
South Florida
Yes, how we have it listed on the website should be accurate from what we can tell. Raptors still use the prior design while the 26+ Broncos are using the updated housings without the cut out in the side.
