2021+ Ford Bronco Standard Bumper 40” Light Bar PRO
MandRautomotive
Mikhail
CA
*** Don’t Forget: Forum Members Receive a 10% DISCOUNT!!! Use Coupon Code BRONCO6G ***
Hey guys,
Upping your Bronco’s lighting is easy and affordable. One of our most popular light bar kits is the M&R Automotive Ford Bronco Standard Bumper 40” Light Bar Pro.
This kit is super easy to install:
1) No drilling. Complete bolt-on.
2) You do not need to remove the bumper
3) lifetime warranty
4) Can tap directly into your AUX switches if equipped. If not we have a perfect solution (M&R Wireless Harness)
Ford Bronco 2021+ Ford Bronco Standard Bumper 40” Light Bar PRO Screenshot 2026-06-15 at 4.58.01 PM
Fits only Ford Bronco Standard Bumper years 2021 2022 2023 2024 2025 2026
  • Curved LED light bar PRO
  • Perfectly follows the Ford Bronco Standard bumper curvature
  • Stays slim to the bumper for a sleek, built-in look
  • Quick and simple install
  • Don't need to remove grille or bumper
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
DUAL COLOR: White with Amber DRL
Main White LED Light with Amber DRL (daytime running lights)
  • White LED -- Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the oncoming traffic and also violate road safety.
  • Amber DRL -- amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads; it doesn't blind oncoming traffic.
DUAL COLOR: Yellow with Amber DRL
Main Yellow LED Light with Amber DRL (daytime running lights)
  • Yellow LED -- used in poor driving conditions such as dust, fog, snow and rain. It reflects through air particles much less than the white light, making it ideal for poor driving conditions. For off road use only.
**Please note** The yellow lens alters the look of the amber DRL, making it appear a little darker than with the white lens. Check the photos to see the difference.
  • Combo Pattern: combined spot and driving optics offer a balance between distance and width
  • Uses a TIR (Total Internal Reflection) lens, which is different from our regular slim light bar. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
  • Higher light efficiency: brighter, longer irradiation distance
  • Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading and scratch resistant.
  • Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
👍Our light kits are for off-road use only.
For More information on the M&R Ford Bronco Standard Bumper 40” Light Bar Pro, Click HERE
MandRautomotive
MandRautomotive
Mikhail
CA
CalvinT
Calvin
Phoenix, AZ
I'd be more interested if you posted beam patterns or gave some indication of how well these do on a dark road. I buy lights so I can see, not to look at. Appearance is important. That's why I'm curious about your lights.
psdtime
Tom
CA
2026 Bronco
I can show you the light pattern of a 30" Pro model. I'm really happy with it. Gate is about 200 feet away. (Amber/Yellow)
Ford Bronco 2021+ Ford Bronco Standard Bumper 40” Light Bar PRO 1781642526194-es
This will give you an idea of how narrow it is.
Ford Bronco 2021+ Ford Bronco Standard Bumper 40” Light Bar PRO 1781642574014-hm
Ford Bronco 2021+ Ford Bronco Standard Bumper 40” Light Bar PRO 1781642699780-x
CalvinT
Calvin
Phoenix, AZ
How much better are they than the Bronco Signature lighting?
Ford Bronco 2021+ Ford Bronco Standard Bumper 40” Light Bar PRO 2021 Ford Bronco 4-door SUV Signature lighting LED
CarGuy
New Jersey
2023 Ford Bronco
I have their standard 40” straight light bar and it throws a lot of light.
psdtime
Tom
CA
2026 Bronco
No idea, but you can compared to my BD Pro Spots, Pro Combos and fogs combined (photo below). After I took this, I adjusted the spot more towards the middle. I'm no lighting pro, but I am impressed with this light bar. Glad I went with yellow so that I could choose what is best for the conditions. All photos are with the headlights off.
Ford Bronco 2021+ Ford Bronco Standard Bumper 40” Light Bar PRO 1781665424301-t4
Wolfgang VTS
Terry
East Tennessee
2025 Bronco Base, 2021 Ford Ranger, 2022 Ford Bronco Sport
Hey guys,
2) You do need to remove the bumper...
I'm assuming that the former is correct.
Your post is somewhat confusing...
