- Andrew
- Feb 19, 2026
- 7
- 47
- 107
- New Hampshire
- 2025 Bronco, 2020 F150, 2017 F350, 2024 F550
- Badlands
Here are some details on our coilover offerings for the Bronco (non-Raptor) applications.
BRBN Coilover Spec Sheet:
Bronco Standard Front Kit
Bronco Standard Rear Kit
Bronco HD Front Kit
Bronco HD Rear Kit
Shock Dyno Data
Spring Rates:
Bronco Standard Series Front: 560
Bronco Standard Series Rear: 224
Bronco HD Series Front: 672
Bronco HD Series Rear: 270
Coilover Length:
Front Extended Length: 23.4
Front Compressed Length: 17.9
Rear Extended Length: 26.0
Rear Compressed Length: 18.5
Thanks for looking, any questions let me know!
- Andrew
- Premium Materials: Coated 2.8” aluminum shock body, 6061-T6 billet-machined aluminum reservoir & components, anodized finish, 65mm (linear) piston, and chrome-plated shaft.
- Adjustable Ride Height: 2 to 4 inches of lift to set your ride height and clearance for wheel/tire combos and terrain. Sasquatch package equipped Broncos will obtain a 0 to 2 inch lift adjustment range.
- 3-Way Damping Adjustment: Independent high-speed compression, low-speed compression, and rebound adjustment for precise damper tuning.
- Monotube Damper Design: Maintains consistent damping under extreme loads.
- Available in standard spring rates or HD spring rates.
- Limited Lifetime Warranty
Bronco HD Front Kit
Bronco HD Rear Kit
Shock Dyno Data
Spring Rates:
Coilover Length:
- Andrew
