WolfBox
Florent
LA
2021 2dr Bronco
Edit:
Sorry for causing this inconvenience, my dear friends.
For those who ordered, I managed to get another $20 gift card that can be applied both on wolfbox.com and gears.wolfbox.com, which can be added to the $15 card sent from our customer center on Wolfbox Gears.
Please kindly fill your email address and order number in the sheet below, once we confirmed, you will receive it.
Wolfbox side mirror orders
I'll update the compatibility and features here as soon as I have the info. Thank you for your patience.
Dear friends,
Please allow me to make an introduction to Wolfbox Wide-Angle Convex Side Mirrors.
Command Your View. Drive with Confidence.
Stop letting restrictive factory glass limit your situational awareness. The Wolfbox Wide-Angle Convex Side Mirrors are the ultimate visual upgrade for the 2021-2026 Ford Bronco, specifically engineered to eliminate dangerous blind spots during technical off-road maneuvers. Whether you are rock crawling or navigating dense backcountry trails, our precision optics provide the expansive field of view your rig deserves.
Key Features & Highlights:
  • 1:1 OEM Precision Fitment: This is a complete glass replacement unit, not a stick-on mirror. Specifically designed to snap directly into your Bronco factory mirror glass base for a secure, vibration-free fit that maintains your rig's rugged engineering.
  • Advanced R1200 Wide-View Optics: Engineered with specialized convex curvature to expand your peripheral vision by approximately 30%. See the entire trail—not just your fender—to spot obstacles earlier and reduce neck strain during intense off-road sessions.
  • Standard All-Weather Heating: All mirrors come standard with the heating feature. Simply connect to your Bronco's factory wiring to quickly clear frost, fog, and water droplets for crystal-clear visibility in any environment.
  • Optional Anti-Glare Blue Tint: Choose our Nano-coated blue glass upgrade to effectively filter out blinding high beams and harsh sunlight reflection without the need for complex electronic sensors.
  • Upgradeable Sequential Turn Signals: Complement your Bronco's modern lighting with an optional plug-and-play sequential turn signal upgrade. Easily tap into existing wiring for a sophisticated, flowing look that enhances safety.
  • Upgradeable Blind Spot Monitoring (BSM): Maintain your factory safety tech. Choose our BSM-compatible upgrade to ensure your blind-spot detection system continues to function perfectly while you're on the move.
  • 3-Year Limited Warranty: Wolfbox stands behind its precision optics with a 3-year limited replacement warranty, protecting against structural and workmanship defects.
Mirror features:
  • Heated
  • Heated + Blind Spot Monitoring
  • Heated + Turn Signal + Blind Spot Monitoring
Mirror color:
  • Clear (original)
  • Blue (Reduces Headlight Glare)
Master Your Surrounding Awareness:
Don't settle for limited visibility when the terrain gets tough. Snap it in, see it all. Upgrade your Ford Bronco today with Wolfbox Smart-Fit Wide-Angle Convex Mirrors and conquer the backcountry with a full-field view.
Fitment:
YearMakeModel
2021 - 2026FordBronco
Exclusive forum discount code: MIRROR15.
Better view for safer driving!
Purchase Now!
HeHateMe
San Antonio, TX
2020 Hyundai Palisade
Looks like a winner... 👀
timbits588
WNY
2017 Expedition EL Limited, 2023 F-150 Lariat, 2023 Bronco Wildtrak
I'll have to take a look. I like the option for no blue/tint. I also like the 3 year warranty. That's pretty impressive.
mdainsd
2025 Bronco, 1974 Bronco, 1969 Bronco, 2014 Raptor, 2012 MegaRex
Definitely going to check these out.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
ordered
WildHorseJoe
Joe
Binghamton, NY
2025 Ford Bronco Badlands Sasquatch
Ordered!
foreWard
Ward
RVA
2022 Badlands
ordered. I'll let you all know how it goes. Happy with my rearview mirror from these guys.
Gene Dios
Atlanta
Heck yes, been on the lookout for this for ages. I'll be ordering a set :thumbsup:
AMCheese
CA
Gonna order a set, wondering how the sequential turn signal feature wires up? Didn't think any trim had turn signals in the mirror housing.
Nitwit
Loudoun County, VA
2025 Ford Bronco, 2000 Audi S4
Ordered. Can’t wait to get these installed.
RedBeardoh
Matt
WA
2019 Ford Ranger
Also curious about this… ordered mine with them. Will find out soon enough..
Raybj
Ray
Milford, Ct
24 Bronco Wildtrak Sasquach 2dr
Dear friends,
Mirror features:
  • Heated
Mirror color:
  • Clear (original)
Fitment:
YearMakeModel
Purchase Now!
Just bought a pair.
