infotainment
Lux Sponsor (Level 2)
Oviedo, FL
2022 Ford Bronco
Hey Bronco Owners,
If you’ve ever wanted true keyless convenience for your Bronco, this is the upgrade you’ve been waiting for. The 2021–2026 Ford Bronco Wireless SecuriCode Keyless Entry Keypad Upgrade is now available. This upgrade gives you secure, keyless access to your Bronco without needing your key fob with no wiring and no complicated install. Just mount it, program it, and go. If you’ve been looking for a cleaner, smarter way to access your vehicle, this is it.
🔑 What Is It?
This is a factory-style wireless keyless entry keypad that mounts directly to your Bronco using adhesive with no wiring, no complicated install.
  • Lock your keys safely inside your vehicle
  • Unlock your Bronco with a simple 5-digit code
  • Fully integrates with your vehicle using included programming tool
How It Works
Once installed and programmed:
  • Enter your unique 5-digit code to unlock your Bronco
  • Add a secondary custom code if needed
  • Lock the vehicle instantly without entering a code
Everything works seamlessly with your Bronco’s factory system
Installation (1/5 Difficulty — Easiest Upgrade You’ll Ever Do)
This is one of the simplest upgrades you can add to your Bronco, but it solves a very real problem. No more juggling keys, hiding fobs, or worrying about access when you’re away from the vehicle. It’s clean, secure, and works exactly like a factory feature should.
Use code bronco6g15 at checkout to receive an exclusive 15% off discount for all forum members.
💬 Have Questions?
Our U.S.-based team is ready to help:
📞 Call: 1-855-636-6287
📧 Email: [email protected]
timhood
Tim
Several
This is cool, and I assume exactly as capable as the OEM version. Even though the website instructions state “ensuring the numbers run 1 through 9 from top to bottom,” I assume this could be mounted horizontally just as well. A favorite mounting location for some is inside the fuel door.
If I hadn’t spent my Ford Pass points on the OEM version, I’d have been a customer. Does the programmer have any use after installation? Maybe you could offer a core refund for returning it?
BroncoBeachBuggy
Montauk, NY
F-150
As mentioned, people have put these inside the fuel door. Does this fit and does it work if mounted horizontally inside the fuel door? Looks a little longer than OEM. If it works inside the fuel door I am a customer.
CliffordTheBigRed
Hilary
Golden
Chrysler Pacifica
Hey Bronco Owners,
🔑 What Is It?
How It Works
💬 Have Questions?
The video says it’s only for up to 2024 models. Does this work for 2025?
bproyall1
Brad
Jacksonville, NC
2025 Ford Bronco Badlands Sasquatch
I have a 2025 with a 7MT so I don’t have remote start and it is the only option for 2025 models. Does that mean it won’t work if you have a manual transmission???
Wichadicha
Usernamedcastle
Georgia
2025 Bronco
You need the remote start functionality "I Believe" as that includes an additional antenna "I Believe" that is needed for any of these to work. If you have that then they will work for all years as I have added them to a 2023 and a 2025
SHANUT
Craig
Hermann, MO
I got the dealer installed factory option and this is exactly what they installed and it’s on a manual. They programmed it and I stuck it horizontally on the door right above the door handle where it belongs. Works great.
SHANUT
Craig
Hermann, MO
I got the dealer installed factory option on my 2025 with the manual transmission and this is exactly what the unit looks like that I have. The dealer programmed it for me because I didn’t wanna mess with it and then I stuck it on horizontally right above the door handle where it should be. In all honesty I installed it inside the fuel door at first and hated it there so I got the old hairdryer out, heated it up and moved it to the door.
Dustin
How does it not lose power over time and lock you out? Am i overthinking this?
psdtime
Tom
CA
2026 Bronco
Ha. Even the factory installed ones die every few years. Not overthinking. Maybe just thinking too soon 😊
There are not replaceable batteries inside it?
Wichadicha
Usernamedcastle
Georgia
2025 Bronco
Wrong, that's what they indicate but it is quite easy to remove, swap battery, re-apply new 3m double sided tape and stick back on. They last for many years
timhood
Tim
Several
What @That Bronco Guy said, but know that even when the battery on the keypad dies, you can still access the vehicle with the key fob, or even the cut key.
