MandRautomotive
Mikhail
CA
Ape Factory
Michel
Audi RS5/Ford F150/Infiniti QX70S
Looks well integrated and doesn't block much airflow to the radiators like some setups do. Pretty critical on the Raptor. Need to see photos of the light throw at night.
EOD98
Las Vegas
2025 Bronco Badlands Sasquatch
I like it. Nice to have the option to add a second bar.
Moontraveler1984
McCordsville, Indiana
2022 Wildtrak - for Bradford
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
Lots of light BUT too low on vehicle to provide proper down road illumination.
HalfmuleFarmer
Thomas
2025 Badlands
Concur, but maybe that’s not its designed function. Lower light = see what’s in front of you. Higher lights = see the environment and the distance. Each has its use.
Steve_In_29
St Johns, Arizona
Both high and low mountings are about seeing what's in front of you and after a certain amount of light it is simply overkill. Why have enough light to see far ahead mounted down low where it can't be utilized. And where it won't fill in the shadows to allow determining if there's a hole that needs to be avoided
Form over function seems to be the case here.
HalfmuleFarmer
Thomas
2025 Badlands
I agree that if you want to see “far ahead” you should put lights on the roof. This bar seems more about trail illumination, close not far, supplemental to the not great OEM headlights and/or fogs (if you even have fogs — a lot of mod bumpers don’t).
23OBX2.7
AB Canada
2023 Bronco
Bronco is not nearly fast enough to need long distance lighting IMO .
MandRautomotive
MandRautomotive
Mikhail
CA
MandRautomotive
MandRautomotive
Mikhail
CA
This is a single 40" PRO series lightbar on a F150. It should give you an idea of light output. We will make a double stacked output on a bronco soon.
