MRTperformance
Plymouth, MI
www.shopmrt.com
2024 Ford Bronco
Ford Bronco No-Drill Hood Struts NOW Confirmed for Everglades & Snorkel-Equipped Broncos! (From MRT Performance) IMG_1033
Hey Bronco6G!
We know this has been a major frustration point for our off-road and Everglades community members. For a long time, the snorkel has been a deal-breaker for nearly every hood strut kit on the market.
We're excited to confirm that our team has secured 100% confirmed fitment for our No-Drill Hood Strut Kit on the:
Bronco Everglades Edition
Any 2021+ Bronco equipped with an aftermarket snorkel.
Why MRT's Hood Struts?
This kit finally lets snorkel owners ditch that annoying factory prop rod and enjoy hands-free engine access:
No Drilling Required: Our struts utilize existing factory attachment points for a simple, do-it-yourself installation in about 30 minutes.
Clear Engine Bay: Get a full, clear view of your engine bay without the prop rod getting in the way.
Quality & Craftsmanship: Designed, crafted, and manufactured in the U.S. at our Plymouth, Michigan location.
Clean Look: Mounting brackets feature a durable black powder-coated finish for exceptional corrosion resistance.
This is the solution you’ve been waiting for—functional, reliable, and perfectly engineered for the snorkel clearance challenge. The Bronco Everglades Hood Strut Kit is currently $74.99.
➡ Check out the kit and grab yours here: https://www.shopmrt.com/2021-Bronco-MRT-No-Drill-Hood-Lifts-80K115-p/80k115.htm
Koss_co
Everglades
2024 Bronco, 2022 F-150
Everglades
Yes! Finally. Putting in an order. Thanks!
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Nice. Just added their struts to my 2021 badlands. Great product.
Ninjak
Miami
I had these on my Badlands with an ADV hood. They were the truth. Very good product.
Glade Runner
Everglades
VA
Yes
Everglades
Is this just one strut? Or are there struts for both sides, since none of the photos show the snorkel side?
MRTperformance
MRTperformance
Plymouth, MI
www.shopmrt.com
2024 Ford Bronco
This setup is only on the driver side to accommodate the snorkel on the passenger side.
Koss_co
Everglades
Everglades
Wait, so I just paid 80 bucks for just the one side? What else do I need for both on my Everglades?
MRTperformance
MRTperformance
Plymouth, MI
www.shopmrt.com
2024 Ford Bronco
The Everglades Hoodstrut kit is designed with a single, heavy-duty gas cylinder that supports the entire weight of the hood. This eliminates the need for a passenger-side strut, as the factory mounting points are obstructed by the snorkel.
Ninjak
Miami
Will say this first: I DO NOT WORK FOR OR AM IFFILIATED WITH MRT.
That out of the way, I had these struts on my Badlands with the ADV hood. I had the driver's side on, and while testing the operation, the driver's side alone was able to hold my hood up. With the passenger side, the hood was pushed up once I unlatched it. These struts I purchased was not design for one strut use.
So if the new strut is designed for the Everglades to operate with just one, I am quite confident it will work the way MRT worded their statement.
Jakob1972
Everglades
Steven
Spring Branch, TX
2025 Trax 2RS, 2022 Camaro, 2022 Silverado, 2004 Fummins F250, 2008 Chevy Cobalt
Everglades
Hmm I wonder if it will fit on my Glades, I added a 150A breaker for my air compressor, on that side.
Ford Bronco No-Drill Hood Struts NOW Confirmed for Everglades & Snorkel-Equipped Broncos! (From MRT Performance) IMG_2524
Koss_co
Everglades
Everglades
Ahhhh. Ok. I get it. Thanks so much for clarifying. Can't wait to get it installed. Thx MRT
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
As a truck engineer, I say supporting the hood entirely on one side is not ideal.
The hood may be supported more or less in the center, or on both sides.
The post led one to believe they had engineered a proper left and right side mounting arrangement. But no.
The photograph on the link shows next to nothing. I do note the weight of the hood is propped down at the bottom, creating significant mass stress.
MRTperformance
MRTperformance
Plymouth, MI
www.shopmrt.com
2024 Ford Bronco
We actually agree with you—that’s why our standard kit for all non-Everglades Broncos includes mounts for both sides to balance the load.
This specific photo shows our solution for the Everglades trim. The factory snorkel makes a passenger-side mount impossible without major modifications.
While single-sided support is problematic on heavier applications—trying this on a Foxbody Mustang would be a no-go—the Bronco is different. Due to the lighter nature of the Bronco hood, we were able to design a specific bracket and strut combination that minimizes the twist and stress issues that traditionally arise with a single prop. We refused to design for inferior mounting points just to force a dual setup; instead, we utilized rugged factory points to ensure dependability. We waited a long time to release this kit to ensure it passed stress testing, and the results have proven we pulled it off.
