j_marinelli
Spring Branch, TX.
Just got an email on the release of these new headlights and thought I would share. Current pricing on them is $899.99 (with a $999.99 retail)
https://dv8offroad.com/collections/...ghts/products/6th-gen-bronco-headlights-black
Our 6th Gen Bronco Black Headlights give your rig a sharper, modern look. Each unit packs a 90-watt LED system that throws out a crisp 6500K color temperature, delivering 3,650 lumens on low beam and 4,700 lumens on high. The projector-style optics keep the beam focused and clean, while the LED white DRL halo and amber centerline light bring a distinctive signature you won’t mistake for anything else. Integrated amber side markers add both style and on-road awareness.
The housings are IP67 rated to withstand water, dust, and trail abuse, and they include 3° upward and 5° downward adjustability with simple, tool-friendly tuning. DOT/SAE compliance ensures they meet safety standards. Each pair features a laser-etched DV8 logo on the lens for a finished look. Sold as a pair and designed for straightforward installation, these headlights upgrade your Bronco’s visibility & style.
Key Features:
  • Color Temperature 6500K
  • Input Voltage: DC 12V
  • Power: 90W/Pair
  • Low beam lumens: 3650
  • High beams lumens: 4700
  • DRL lumens: 1150
  • Amber side marker lights
  • Sold as pair
  • LED white DRL halo with amber centerline light
  • Projector style low and high beam
  • 3 degrees (up)/ 5 degree (down) of adjustment
  • DOT/SAE Compliant
  • Easy and simple adjustment
  • IP 67 Rated
  • Laser etched DV8 logo on lens
Ford Bronco New Product - DV8 Offroad Black Headlights for Bronco 6th-gen-Ford-Bronco-Black-Headlights_558x372
Ford Bronco New Product - DV8 Offroad Black Headlights for Bronco 6th-gen-Ford-Bronco-Black-Headlights-2_557x372
Ford Bronco New Product - DV8 Offroad Black Headlights for Bronco 6th-gen-Ford-Bronco-Black-Headlights-1_558x372
Ford Bronco New Product - DV8 Offroad Black Headlights for Bronco n-Ford-Bronco-Black-Headlights-installed-1_558x372
Ford Bronco New Product - DV8 Offroad Black Headlights for Bronco h-gen-Ford-Bronco-Black-Headlights-Event-8_557x372
Ford Bronco New Product - DV8 Offroad Black Headlights for Bronco h-gen-Ford-Bronco-Black-Headlights-Event-6_558x372
Ford Bronco New Product - DV8 Offroad Black Headlights for Bronco h-gen-Ford-Bronco-Black-Headlights-Event-2_557x372
Install Guide
Returntothefog
2025 Bronco Heritage Edition
I think they look really good, a fresh breeze of aftermarket headlights that’s modeled after the standard OEM LED headlights instead of the Signature ones! Just need some more market feedback and field test from ppl on here
KillerPenz
North East
Not a fan of the non-signature light, though my kid would probably be interested for his Bronco.
What I don't like is the 2-piece headlight. I've read far too many complaints about headlights that follow this design, mostly issues with flickering or wiring harnesses, but there were other complaints as well..
What's so difficult about making it a one piece? headlight + marker light, avoid having to screw in extra shit.
Honestly, this looks like the Rough Country headlights. Granted probably better quality, which I would for being that it's twice the price of the RC's.
Ford Bronco New Product - DV8 Offroad Black Headlights for Bronco RC headlight
j_marinelli
j_marinelli
Spring Branch, TX.
Sure does :unsure:
Ford Bronco New Product - DV8 Offroad Black Headlights for Bronco 21-24_bronco_headlights-rch5500
KillerPenz
North East
Aw shit, specs pretty similar to the RC's as well.
  • DOT/SAE Certified for street legal use.
  • IP67 Waterproof Rating.
  • Excellent Heat Dissipation - Built-in fan and space in housing to insure greater heat dissipation.
  • Anti-scratch lens & housing.
  • Adjustable Beam Pattern - Adjuster screw on back housing to adjust beam angles accordingly.
  • Distinctive Chasing Daytime Running and Amber Sequential Turning lights.
  • Delay to turn off - headlights automatically turn off.
  • 50° wide angle - 50° wide angle for low beam for better viewing and safer driving.
  • Color Temperature: 6500K
  • Voltage: 12V DC
  • Actual Power (one light): 47W High Beam, 36W Low Beam, 12W DRL, 39W Turn Signal, 8W Side Marker
  • Raw Lumens: 4700LM High Beam, 3650LM Low Beam, 1160LM DRL, 3900LM Turn Signal, 800LM Side Marker
  • Outer Lens Material: PC
  • Housing Material: PC+ABS
  • Housing Color: Black
Hey @j_marinelli are you slapping a DV8 sticker on a set of RC's and raising the price? :ROFLMAO:
Returntothefog
  • Voltage: 12V DC
Aw sh* here I thought it’s some novel design… welp, hope quality is better, from the lack of talks about the RC ones I reckon the quality left a lot to be desired…
Also DRL sequential turn signal would be nice I’m not sure if any of them after market options has this function
KillerPenz
North East
The RC ones are. If you go to their website they have a video of them in action.
https://www.roughcountry.com/product/drl-halo-led-headlights-rch5500
I get it, RC has NEVER been the best quality, it's always been a budget option. But for me, I kind of prefer budget options, IF they work.
Sorry J_mar, not trying to hijack your thread.
j_marinelli
j_marinelli
Spring Branch, TX.
Form headlights re sequential but is only the line where as these are line and halo are sequential on turn signal (Form's halos have a start up sequence only)
j_marinelli
j_marinelli
Spring Branch, TX.
Returntothefog
Yea form is the popular aftermarket option, but I somehow the non signature headlight look where the DRL doesn’t go all the way through
KillerPenz
North East
I'm rocking the Morimoto's so it's all sequential. Looks like the RC's are all sequential as well.
2021FordBronco2
Jo
Nampa, ID
2024 Ford Bronco Big Bend
I am probably one of the few people that like the base headlights and tail lights
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
